Old 08-19-2010, 08:18 PM   #1
skysoldier173rd
skysoldier173rd's Avatar
350 installed
Today i installed the SBC /700R4 in my 60 GMC. I had a 86 donor truck and used the mounts from it in the 60. I just had to add a 1" shim under the mounts, but after that, it fit like a glove, I mean tight and exact, no slop whatsoever, so it took awhile to squeeze it in there. Had to lower it in with the mounts on the engine, put it in place, mark the holes for the mounts and take it back out. I then drilled the holes for the mounts I had marked and put it back in again. Quite a little work, but worth it. Now, I got a lot of things to install, and also need to make a crossmember and have a driveshaft made. Just glad to have the heavy work out of the way. Thanks to everyone for giving me the right information on how to handle the mount setup.
skysoldier173rd is offline   Reply With Quote
Old 08-19-2010, 09:51 PM   #2
losthope
losthope's Avatar
Re: 350 installed
very cool!
losthope is offline   Reply With Quote
Old 08-19-2010, 10:00 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: 350 installed
Nice job....always a lttle scary when that thing is hanging over the front of the truck ....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-20-2010, 12:38 AM   #4
Captainfab
60-66 Nut
Re: 350 installed
Glad to see you've got it in there. Have you changed the front suspension yet? You can likely use the '86 trans crossmember to make one for your '60.
Old 08-20-2010, 08:09 PM   #5
WellBilt Kustoms
Re: 350 installed
Good Job! Always better to take your time, do it right, and only do it once.
If your looking for any engine dress up parts, let me know...i have a bunch of stuff i'm trying to get rid of from a project that didn't go thru. Few performance parts as well, but mostly dress up stuff.
WellBilt Kustoms is offline   Reply With Quote
