Old 08-21-2010, 02:07 AM   #1
jojo
printing is my trade
jojo's Avatar
Aftermarket A/C with Factory Heater
If this has been addressed in another thread please let me know.
I've read complaints about guys not being able to defrost their window with aftermarket a/c.
I wanted to know this is possible (or even if anybody thinks its necessary in hot texas):
Can I install aftermarket A/C with factory heater core in order to retain a proper defrosting capabilities?
My concern is not only the cold but rather when it rains, is it needed to have the defroster?
Looking for anybody's input, since I'm hoping to pull the trigger on purchasing the system in the next few weeks..
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 08-21-2010, 11:00 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Aftermarket A/C with Factory Heater
ttt -- I'd like to know also and in case someone knows the answer.
However, I think the best thing to do is to contact the manufacturer before purchasing to see if the unit has a defrost option. We need the defroster here in Texas like anywhere else -at least where I'm at.
I'm not positive on this one but I don't think the old vehicles did not have the ac/defrost option back then. You either had ac or defrost but not both and the ac is what quickly removes the moisture.
68gmsee is offline   Reply With Quote
Old 08-21-2010, 01:21 PM   #3
magicoolbus
magicoolbus's Avatar
My 'vintage air' sure fit AC unit has heat and defrost. The defrost setting does turn the compressor on and gives your the 'dry air' needed for proper defogging, you just adjust the temp lever for the desired heat range. If your looking to keep the engine bay stock looking, I don't have an answer for you.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 08-23-2010, 09:46 PM   #4
425HP409
425hp409
425HP409's Avatar
See the thread "Vintage Air" today at 7:15 pm.
I have installed many of the Vintage air type systems, the defrost works better than the factory heater/defroster as it turns the ac compressor to dehumidify the air. I had an underdash air system in my truck and I would just turn on the AC with the defroster when I wanted to defrost the windows fast.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 08-24-2010, 11:01 AM   #5
Lemield
Lemield's Avatar
Nostalgic Air Products sells an underdash system that leaves the stock heater system intact, except for a small modification to the heater box as illustrated in the pictures on their website.
Vintage Air and others make great systems but they all supply a fiberglass or plastic glovebox insert.....I have a custom glovebox radio and I don't want to give that up....so the underdash system from NAP is the best choice I've found. I am planning to order one soon.
http://www.nostalgicairparts.com/air...system-351.php
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 08-24-2010, 01:52 PM   #6
69sixpackbee
...but NONE of them offer outside fresh air or blending capabilities. Been there and done that. The evaporator cores on most of those "hotrod" systems equal the size of the ones in a hallway water fountain! After tinkering with two "aftermarket" systems from reputable mfg's that I need not name as they are top suppliers to the industry, I did myself a favor and fabbed in an OEM Four Seasons setup to my original non-air truck. This has been the best addition to date.
Nothing beats the factory system!
69sixpackbee is offline   Reply With Quote
Old 08-24-2010, 03:10 PM   #7
Lemield
Lemield's Avatar
I totally agree that the factory GM stuff is the best.
Larry
Old 08-24-2010, 04:09 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Lemield View Post
Nostalgic Air Products sells an underdash system that leaves the stock heater system intact, except for a small modification to the heater box as illustrated in the pictures on their website.....
I like this unit from Nostalgic Air, but it says it doesn't work with manual tranmissions. I wonder what that has to do with the a/c?
http://www.nostalgicairparts.com/air...system-405.php
Old 08-24-2010, 04:12 PM   #9
Lemield
Lemield's Avatar
Good question....I've been told their customer service is really good, so you might want to email them or call and ask.
Larry
Old 08-24-2010, 04:30 PM   #10
69sixpackbee
Probably because the floor shifter will smack it But the column shift should be okay.
