FUEL CELL GURU
It is time for a FuelCellGuy group fuel cell buy. What we have is an 18-20 gallon (your choice) fully baffled, sure-fit, fuel cell kit. Kit INCLUDES tank, sending unit, filler neck (your choice thru the bed or 90 degree), and mounting hardware. The tank is constructed of .125 wall aluminum. If you are running fuel injection, an in-tank pump assembly is available for $230. Our regular price on this particular tank is $425. I am dropping the price to $415 + shipping for the first 5 tanks committed to and paid for. I'll drop them to $400 + shipping when we get to 10. Slight modifications can be made without incurring any additional costs. This group buy will include tanks for any year model. The deadline to sign up for the group buy will be September 4th @ 12 NOON. I will accept 50% down to secure your place in the group buy with the balance due before shipping. Please post here or send me a PM. Once again thanks for all the years of loyal support.
BTW, I had to "borrow" a few pics of ones that I have built. Kids deleted all mine. ![]() Last edited by FuelCellGuy; 08-21-2010 at 11:57 AM. |
![]() Join Date: Nov 2007
Re: Sure-Fit Fuel Cell Group Buy!
Making sure I'm correct on the EFI tank price of $645 +shipping?
FUEL CELL GURU
That would be correct.
Interested and subscribed
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
interested how much shipped to 95993 going LSx so I would need a efi pump to support that...the 20 gallon is a direct fit bolt in? or do modifications need to be made?
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 |
anything for the surban in the 30 gallon plus size?
thx, Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
Old and crusty
![]() Join Date: Jan 2009
Does this tank fit the 64-66 trucks?
FUEL CELL GURU
SWB4x4, the only modification to the truck is removing the spare tire crossmember, other than that, drill a few holes and bolt it up. I have rarely shipped a tank in the Continental US that was more than $50.
IAFF2407, If you can help me out with a few dimensions, we can make it happen. dean jendro, Yes, they will. |
#9 | |
Old and crusty
have wood floor can u move filler to fill in center between SS runners?
bogey5 |
FUEL CELL GURU
soala70, Yep!
![]() Join Date: Aug 2004
Fuelcellguy,
Do these come with the sending unit also? also any reason to come into DFW sometime soon?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 08-24-2010 at 11:31 AM. |
Truck and auto performance nut
Hmmmm will have to give this some thought.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
FUEL CELL GURU
Clyde65, sending unit is included and installed. I am in Dallas all the time.
#15 |
so whats the difference (other then capacity and maybe size) between the 18 and 20 gal. tanks? Where's the extra 2 gal? Is it just deeper or ?
#16 |
FUEL CELL GURU
68GMCCustom, another 1" deep yields 2 gallons.
#17 |
so the pic on the left is the 20gal and the right is the 18gal?
#18 |
FUEL CELL GURU
One on the left is 18 gallon. 20 gallon would be an inch deeper.
#19 |
oh OK....to me the one on the right looked shallower then the one on the left.
#20 |
Bump back to the top.
#21 |
Have you done any of these for guys with porterbuilt dropmembers? I do plan on raising the bed floor a few inches also if that helps.
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast" 68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger" |
#22 |
FUEL CELL GURU
#23 |
I don't have the dropmember installed but the frame dimensions shouldn't change. I could be wrong but I'd imagine I just need a stock gas tank probably moved higher in the frame to where only 3 or 4 inches stick below the bottom of the frame. I guess I was thinking you might have made one of these before for someone else that had the porterbuilt dropmember and could just duplicate that.
#24 |
FUEL CELL GURU
Actually, the standard tank hangs below the frame only three to four inches.....
#25 |
In that case put me down for one
Tags |
fuel cell, fuel injection, fuelcellguy, gas tank, rear mount tank |
