08-22-2010, 09:13 AM | #1 |
Correct drvs alt mounting brackets
Would anyone have a pic of the correct mounting hardware for the drvs side V8 with the original manifolds?
The set I have is not correct. It hits the embossed section of the exhaust manifold. Asked a few members parting out trucks if they have any available but want to make sure this time I ask for the correct ones. Last edited by 67gmcstepside; 08-22-2010 at 09:15 AM. |
08-22-2010, 09:54 AM | #2 |
ran out of money
Re: Correct drvs alt mounting brackets
looks like its time for headers! j/k I'll take a look at mine today and get a few pictures for you (im not 100% sure mine are orig. but I know my alt uses that bracket)
Modify everything, leave nothing alone!~ |
08-22-2010, 10:23 AM | #3 |
thats the correct bracket so i'd think the problem is with your manifold not the bracket
08-22-2010, 10:24 AM | #4 |
In another pic I just looked at with the alternator mounted, it looks like the bottom mount is lower on the head than what your holding it. I haven't been outside to look at mine yet so that's all I'm going off of. The pic is in the parts section in the thread "69 c10 for sale".
-Scott- Last edited by sjarrett71; 08-22-2010 at 10:25 AM. |
08-22-2010, 11:11 AM | #5 |
Old member
Here is one looking down on it.
Front underside looking at it. Close up. You can see I made some spacers for it. This was to align the pulleys though not to clear the exhuast. From behind it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-22-2010, 11:23 AM | #6 |
Who's got steelies?
The bracket you show on your post is a 69-72 alt bracket. You'll have to switch to 69-72 exhaust manifold to use it. Here is a picture of the 67-68 bracket that uses the bosses on the manifold:
I hope this helps.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 08-22-2010 at 11:23 AM. |
08-22-2010, 02:11 PM | #7 |
Thanks for all the replies! Oldgold, thanks for that info. Now to find the correct brackets.
