#101 |
Never Ending Projects
Re: 1963 C10 SWB Big Window Build
Build is looking great.
Man I sure wish you were futher down near SoCal. I would SOOO love to get that rear suspension parts from you, since the PO had converted mine to leaf springs and I want to go back to the coil setup. Keep up the good work!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#102 |
Man that truck is gonna be SICK...the front IFS and rear c-notch kit is beautiful, like metal-fab artwork...the fellas at Porter Built have some serious skillz!...can't wait to see it finished.
#103 | |
Jesse
Thanks man |
#104 |
Jesse
Well it's back on the ground today and it looks great, let me know what you guys think so far...
#105 |
1 thing at a time is progress.
I like it!!
Alan
Philippians 2:14-16 |
#106 |
Man that looks good.. I have the same kit but its slowly geting on the pick up..
#107 |
Super Clean!
#108 |
Are you gonna keep those wheels/offset?
Can 't wait to see with the sheet metal on it. |
#109 |
Jesse
#110 |
Jesse
Thanks guys, I need to get started on the brake lines ect...
#111 |
That thing looks great.
I cant wait till mine gets done. |
#112 |
just stumbled on this today after workin on my 63, man that thing is sharp keep up the progess and keep those pics comin! they are motivating me!
1963 C10 Shortbed: project, shaved, slammed 1965 C10 Longbed: 355, 4pd new process, Daily Driver 1991 F150: 300 inline, 3in lift 33s, Stacks. RIP 1992 Dodge 250: 98.5 12valve, 500hp POD injectors, rolls coal... 1986 Chevy 4x4 Shortbed: 4in lift, 33s, daily 1995 2500: 6.5 TD, straight piped, the tow mule |
#113 |
man, that looks great! The PB stuff is freaking awesome!!
#114 |
I like the pink beach cruiser.... Truck is slick as well haha.
USMC Former SGT 2002-2006 Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks. The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891 2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612 |
#115 |
Looking great.
BTW, sent you a PM. ![]()
#116 | |
It looks awsome man...looks like you're doing it right the first time. ![]()
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
#117 |
![]() Join Date: Jul 2008
that truck is pretty radical! keep up the good work!
1965 c/10 swb 1969 c/10 lwb ![]() |
#118 |
Torn between 66 and 78
So your the dude that owns the 54'. It is one of my favorites I have found on the web. Everything about that car is sick!!!
#119 |
Chevy Only Tx
Looking damn good!
Chevy Only Tx......... |
#120 | |
![]() ![]() Join Date: Nov 2008
"Spent some time getting the frame stripped clean of years of grime and oil leaks. Used engine brite, super clean, wire brush, putty knife and finished it with a wire brush wheel on my 4 1/2" grinder. I'm going to wipe it down with acetone and prime and paint it today." I assume you followed the same process/same paint - Rustoleum Pro in a silver color? But if the parts were new from PB did you have to remove some kind of oil or preservative from them? Did they have light surface rust? If so, how much did you worry about that - did you get it ALL off, or just most of it then proceed with the paint prep process you describe? |
#121 |
Jesse
The PB parts came clean & bare from Porterbuilt, and all i did is scuff them up with some 320 grit sand paper and a red scotch brite pad. Then clean, prime & paint.
Rustoleum Pro in aluminum color Last edited by DRTYRAT30; 08-26-2010 at 01:22 AM. |
#122 |
I wish Porter Built sold a setup for my '46. Maybe one they have already would be adaptable?
#123 |
AWSOME WORK!
Tony from Norcal |
#124 |
Any updates?
You got the arms on yet? |
#125 |
Jesse
Arm's?
Not much here, bought a high hump floor section off a board member so i can start to clean up the firewall and paint it. Then on to the Booster/MC, brakes. Still trying to decide if i want to order a GM crate engine from Jegs or not. Having a new motor dropped off at your door sounds nice. |
