Old 08-23-2010, 08:56 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
How do you calculate your gear ratio?
My old mans truck revs at 3200 or something @ 65mph with a 28" tire... When he jacks the back end up and gives the wheel a turn, the driveshaft only turns about 1.8 times... I ran his numbers through a calculator and it said 4.10, so why does the driveshaft only turn 1.8ish times?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 08-23-2010, 09:05 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: How do you calculate your gear ratio?
Nevermind...... Cant remember, I just pop the cover and count the gears....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-23-2010, 09:38 PM   #3
c10seconds
c10seconds's Avatar
Gotta take the diff cover off. There are two numbers stamped side by side on the ring gear. Divide the big one by the small one and that should be you ratio.
c10seconds is offline   Reply With Quote
Old 08-24-2010, 03:52 PM   #4
raycow
You don't have to take off the cover unless you really enjoy draining the oil, getting yourself greasy, scraping off the old gasket, etc.
Put matching marks on the pinion yoke and differential housing. Jack ONE rear wheel off the ground, put the transmission in neutral, and the parking brake off. Turn the wheel exactly TWO revolutions and count how many times the driveshaft turns, estimating any fractional turn as closely as possible. That number is your axle ratio.
If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both rear wheels off the ground and turn either of them only ONE revolution. Count the driveshaft turns the same way as for an open rear.
Ray
raycow is offline   Reply With Quote
Old 08-24-2010, 04:13 PM   #5
cdowns
cdowns's Avatar
draining 40year old rearend grease cleaning and replacing with new grease is a worthwhile saturday project
