#276 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 71 Blazer "Finishing Touches"
Damn she turned out nice good luck with putting those k-5 fender emblems on mine have always been a pain in the butt with the fenders mounted on the truck.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#277 |
Under Construction
very nice Jonathan!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#278 | |
VA72C10
![]() Join Date: Mar 2008
![]() Thanks! Got the grille ends on so I was able to install it and the bumper. Jason used his skills to deal with the passenger door handle that was giving me fits so I was able to get the door panel wrapped up. Got the carpet hold downs installed and the hatch weatherstrip is all on now. Got all the seatbelts in now too! blazer specific passenger belt ![]() ![]() Rear bench belts ![]() Passenger door panel ![]() because the handle is finally done ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#279 |
VA72C10
Man, flash makes things look horrible...
Here is the passenger side 99% done.... ![]() and the front end finally together ![]() ![]()
#280 |
VA72C10
should have the headlight buckets tomorrow or tuesday...still have to tweak the hood slightly...was going to wait till the painter came over with his body guy instead of pulling my hair out
#281 |
Damage Inc
coming along nice
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
#282 |
GEARHEAD
It looks great, getting down to the very last "finishing touches".
I should change the name of my thread to "beginning touches" because it seems every day is a new start to something that will never end... ![]() ![]()
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 08-30-2010 at 07:35 AM. |
#283 |
VA72C10
yep....a little difference between what I started with
#284 |
Grandpa in the rustmobile...
lol^
thats a pretty color, medium blue? factory color?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#285 |
Still Learning
Great job on the Blazer! It turned out great! too bad you have to sell it so soon, what with all the warm weather left, it would be cool to drive it till late fall at least.
#286 |
Tot Roddin'
Looking good Jonathan!
Have you considered side trim?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#287 | |
VA72C10
Yes, factory medium blue. The PPG code for the chevy medium blue cross referenced to a more modern chrysler blue which is what it says on the paint can codes. However, it does match perfectly with the original paint still on the firewall and under the spid sheet on the inside of the glovebox door.
I would love to do it and really think it would bring the truck to another level visually.....but I am going to leave it up to the next owner. If they like it they can put it on...and if they didn't want trim they wouldn't have to weld up any holes since the truck originally didn't come with any.
#288 |
Sofa King Crazy!!
Kinda sad to see a great project come to an end, but a great ride hittin the road makes it worth it!!! We all expect to see some pics of it out in the wild.: )
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#289 |
Man let me tell you that thing is looking so sweet. Of course now that you have the top on I must see pictures of it outside the Garage..
#290 | ||
VA72C10
#291 |
VA72C10
Tonight was frustrating with not having the hardware I needed for the top. Finally found some of the bolts but will have to buy some others tomorrow. Got the courtesy lights all hooked up. All lights now working. Jason was able to do a safety check and checked the timing and all fluids. (He's now a certified state inspector too)
Wanted to take a test drive but not with a loose top. Will hopefully bolt it on tomorrow night and make it to a local cruise-in. Paint is going to be wet sanded and buffed Sunday morning by the paint guy and his top assistant. Can't wait to see it all buffed up to a shine!!! Here's pictures showing the bezels on the lights and the trim rings and center caps I was also able to install with Jason's help on the rings that were kicking my butt ![]() ![]() ![]() ![]() ![]() ![]()
#292 |
VA72C10
Paint got wet sanded and then buffed and is SUPER SMOOTH! Almost finished now.....and got a deposit on it so it'll be going to a new owner soon.
![]() Jason's bike in the reflection ![]() getting the emblems on ![]() and cleaned up the engine after tuning it up and adding a fuel pressure regulator and fuel pressure gauge ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 09-07-2010 at 11:21 PM. |
#293 |
Still Learning
Great job on everything Jon, You really knocked this out of the park and quickly! Hard to believe how fast you got it done. I'm sure the new owner will be happy too. congrats on the sale.
#294 |
Restoration Virgin!
and the new owner is....??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#295 |
Under Construction
Congrats on a job well done... I'm with Geoff, is the new owner a board member?
#296 |
One foot in front of the other
![]() Join Date: Aug 2008
Congrats on the sale- great job
#297 |
Blaze-Air
dribble dribble drool...amazing results.
I'll feel terrible if I don't see this in person before it rolls out. Cruise-in this weekend maybe? Take it on a shake down cruise to F'burg this fri lol... |
#298 | |
VA72C10
gonna have to come up here if you want to see it. Will probably be leaving by Monday or Tuesday...
#299 | |||
VA72C10
#300 |
Don't Forget we need final pictures outside the garage...
![]() Paul |
