Old 08-24-2010, 10:51 AM   #26
1-PU70
1-PU70's Avatar
Re: BB or SB, That is the question!
I had a 307 that I replaced with a 402. The noise is the same. Stock cast iron exhaust manifolds n both. I think most of the unwanted noise coming from the motor is the fan especialy if you have a heavy dutty clutch or no clutch at all. Way more quieter then my power stroke. It is warmer in the cab with the BB but not much. I built mine to tow and it does the job. Stock with a roller cam, high rise cast iron intake, HEI and a 800 q-jet. I get about 13mpg combo city and highway. Im running a 700R4 with 31" tires and 3:73 gears. Good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 08-24-2010, 07:01 PM   #27
69GMC910
MOTORHEAD!
69GMC910's Avatar
Is roller cam the way to go in a big block? I know there's the whole no zinc in our oils today, but I am unfamilier with if it is an easy thing to do in an old BB?? Like in the old small blocks where you have to mount some rail in the lifter valley or something.. Is that the case with the BB? I do not want to go mechanical lifters that's for sure...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
