06-04-2003, 11:09 PM | #1 |
senior member
did i get hosed?
found a edelbrock performer intake in the paper for 100$ (canadian) = 60-75 US.
guy says its 6 months old and was ona 350 so? also I have a friend who took a truck all apart and had the frame sandblasted and powdercoated and all the fenders are off its justa cab with an Inline 6 in it right now he wants $1500 and no rust in the cab corners and itsa 72 chevy
69 GMC bagged |
06-05-2003, 02:50 AM | #2 |
$100 for an edelbrock manifold? Sounds like a pretty good deal to me. You'd pay more for a new one, (plus tax) and it's not as if the manifold can wear out. Clean it up, and it's as good as new. Don't know about the frame and cab though, sounds pretty good.Best of luck with that.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
06-05-2003, 10:23 AM | #3 |
I had someone dismantle my truck,sandblast the frame and paint it and it cost me $800 CDN
06-05-2003, 10:48 AM | #4 |
The intake sounds like a good deal. I've seen people try to sell aftermarket intakes for $125-200 around here. Some have even tried for as much as $75 for the stock intakes.......
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
06-05-2003, 10:54 AM | #5 |
Sounds like a good deal to me. I would make sure that I get
the complete truck. EdB |
06-05-2003, 01:16 PM | #6 |
Good deal on the intake. While they don't wear out, they can be damaged by over torquing, but this usually breaks the ears off. If the $1500 is canadian, that's probably a good deal assuming you get the entire truck. No rust in the cab corners doesn't mean the rockers, floor pan, kick panels and door support bottom (behind the outer rocker) aren't rusted.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
06-05-2003, 02:01 PM | #7 |
Good deal on the intake as long as the Carb and thermostat holes aren't stripped. The truck sounds like an awsome deal. I paid that much for a rusty POS, but the engine and tranny were fresh anyhow.
06-05-2003, 02:35 PM | #8 |
Always check an aluminum intake for corrosion damage around the coolant passage openings and the thermostat hole as well. If it has minor pitting it can be repaired with a little JB weld or similar product. I've seen some pitted out beyond what I'd want on my truck though!
Saskatoon, Saskatchewan Canada |
06-05-2003, 02:37 PM | #9 |
senior member
when i said no rust in the corners i meant the whole cab and rockers floor pans nothing is rusted this truck was looked after
and ya i bought the intake so thanks for the input
69 GMC bagged |
