Old 08-26-2010, 10:40 PM   #1
dzbowtie
dzbowtie's Avatar
water temp sending unit?
i have a 70 c10 which originally had a 6 cyd. i have since replaced the inline with a 350 with a set of vortec heads. i am still using the original water temp gauge. what sending unit do i need to use to connect the original wire. the sending unit will be placed in the side of the head also. thanks for any help
dzbowtie is offline   Reply With Quote
Old 08-27-2010, 12:42 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: water temp sending unit?
The old sender is the wrong size for the vortec head it is too big so here are some options.
http://67-72chevytrucks.com/vboard/s....php?p=3709749
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-27-2010, 11:57 AM   #3
Lee H
Lee H's Avatar
Keep in mind the new sender may not produce a correct reading with the stock gauge. You'll need to verify normal operating temp with an IR gun compared to you gauge reading. I went the vortec route with a 3/8 sender in the manifold and the stock gauge is way off. I ended up installing a set of gauges under the hood so I could monitor engine conditions.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-27-2010, 07:12 PM   #4
Kiwi
Kiwi's Avatar
OK, after reading all of the comments ... does anyone have a part number for a temperature sending unit that will work (without funky machining/tapping) for:
1. 67-72 C10 350 V-8
2. Intake manifold mount (such as for a GM Vortech intake, Edelbrock intake, etc.)
3. Normal temp gauge (not idiot light type)
Kiwi is offline   Reply With Quote
Old 09-21-2010, 06:45 PM   #5
Kiwi
Kiwi's Avatar
I guess not.
Old 09-22-2010, 03:57 AM   #6
raycow
Intake manifold mount is no problem. Every intake I have seen had at least one 1/2" NPT port. The stock sender will screw into that. You only run into trouble when you try to put a sender into the head.
Ray
raycow is offline   Reply With Quote
