Old 08-27-2010, 05:42 AM   #1
karl
karl's Avatar
AC Compressors
Ive noticed that the AC compressors are always grimey looking. Any reason why these attract so much crap? I imagine the dirt gets into the pulley bearings and ruins them. Any good way to clean these without removing?
karl is offline   Reply With Quote
Old 08-27-2010, 07:18 PM   #2
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Re: AC Compressors
I usually pressure wash out my engine bay every so often.. not blast it too hard, but enough to spray the grime away..
that's what I do.. It helps
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 08-27-2010, 11:01 PM   #3
coolair
Re: AC Compressors
Most compressor will leak slightly as they get older and sometimes even when new. The AC system operates @ a high pressure and as the compressor gets older and the seals/gaskets deteriorate, the refrigerant which is mixed with oil will slowly leak out - esspecially at the front seal as it is a slip seal and not a positive seal such as a gasket or o-ring. The oil that leaks out will attract dirt and dust, just like any oil leak will.
The front clutch bearing is normally if not all the time a sealed bearing and they sometimes will loose a little grease, which will also attract dirt.
So bottom line is all you can do is keep cleaning your compressor when you detail your engine compartment.
coolair is offline   Reply With Quote
Old 08-27-2010, 11:33 PM   #4
karl
karl's Avatar
Re: AC Compressors
Thanks, i would rather maintain these expensive parts than to replace then more often. Those clutch bearings seem to be the 1st thing to go. And i thought it might be from all the crap that gathers around it.
