Shock suggestions please
Does anyone have any recommendations for drop shocks? Which ones to avoid? How do your drop shocks ride? Should I just try & get shorter fronts or get some relocators?
Garage Queen Material
Doestch Tech shocks all the way. with as low as your truck is, make sure you get shock extenders for the rear.
ttt
I'd have to agree, go with the Doetsch Techs. They are definitely the best one's I've used on my truck so far. I have about a 6/8 drop and you can really tell when you get a set that works well.
Matt '82 Chevy SWB |
Check this thread out. Not sure if he sold these or not yet.
http://67-72chevytrucks.com/vboard/s...threadid=53970
Scott Shelbourne |
Thanks guys . . .... & thanks for the link BigRed.
Happy to be here
![]() Join Date: Mar 2000
Scoti,
Doetsch Tech's are really good shocks. I have also had great luck with Bell Tech Nitro Chargers. Everyone I talk to say's they suck, but they have worked for me. KYB has a new series out that Cutten Customs swears by. They put the on my Harley truck, and I can't complain so far. Let me know what you want me to get a price on them....
So far, the only ones that I've been able to get dimensions on are the Doetsch Techs so I'll prob give them a try. I might make some shock relocators as well.
driving is in my blood
Had toxic shocks for about a month or two before I couldnt stand them anymore. Switched to doetsch techs and havent looked back
![]() Just a little FYI, but on my oddball 78 with a 5/6 drop, I didnt put any new drop shocks on. I just kept the stock ones on there. That setup had worked better then my 79 with doetsch techs or toxics. Or course this is the same truck that runs 275/60/15's up front without any problems either
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Well there's no possible way to run the stockers since the fronts only have 1.5" of travel before bottoming out & the rears only have 1" of travel before they do.
Interestingly enough, if I take the rear shock extensions off, I could use the fronts on the back. I wouldn't have to worry about them bottoming out . . .... just over extending.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-08-2003 at 01:39 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
