Old 08-26-2010, 06:55 PM   #1
jessewebb
jessewebb's Avatar
Distributor Question, need advice
I'm going to change my distributor in my 69 C/10 and I need some advice. First off, the engine is a sb-350, automatic. has a mild high end cam installed, 600 holley carb. The truck has a newer motor in it. Which distributor would be the best for the engine? a 50,000 volt or a 65.000 volt distributor
jessewebb is offline   Reply With Quote
Old 08-26-2010, 09:17 PM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Distributor Question, need advice
Are you talking about an HEI with the coil included? because its the coil that determines the voltage output not the dizzy.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 08-26-2010, 09:22 PM   #3
Sammy
The answer is yes. Doubtfull your going to tell the difference between the two. If you want to spend money or brag you that you have 65,000 volt coil go that route. If not spend the extra bucks for a fuel line filter or aircleaner filter which you will more likely see some difference in performance or mileage improvement.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-26-2010, 09:38 PM   #4
jessewebb
jessewebb's Avatar
yes its an hei with the coil included.
Old 08-26-2010, 10:04 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
What Sammy said... you're talking about a pretty mild engine.
fwiw, my 350 was rebuilt nearly stock, with an RV cam & Q-jet on an Edelbrock 2101. It has a used GM HEI (no idea what it came from) and it's never let me down.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-26-2010, 11:35 PM   #6
btullis99
btullis99's Avatar
http://www.summitracing.com/parts/SUM-850001R/
all you need.
btullis99 is offline   Reply With Quote
Old 08-26-2010, 11:38 PM   #7
coggonobrien
i just put a tsp 65000v on my 355, very tight fit but works well.
David
coggonobrien is offline   Reply With Quote
Old 08-26-2010, 11:40 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I went to O'Reilly's and got an ACCEL HEI that is essentially a reman unit. It was less than $20 more than a standard reman that O'Reilly sold, which had the same part number as the one from AutoZone and Advance. All were Cardone units. I anted-up for a higher-output coil from ACCEL.
Member Nr. 2770
Old 08-27-2010, 02:53 PM   #9
Keith Grizzle
If you want your distributor to perform at its top peak I use bob jennings dyno shop. He is located at North Hills Ca. His ph is 818-894-3811. He has been setting up dist for 40 years, also quick turn around.He does stock motors and drag motors.
Keith Grizzle is offline   Reply With Quote
