Old 08-28-2010, 12:09 AM   #1
mantisman23
headlights
Tonight when i was about home and my headlights started to go on and off just my headlights though my taillights and park lights stayed on just fine. Is it my headlight switch starting to go out or my dimmer switch. And i also have been noticing the last couple of times i've drove it with the lights on the dash lights are flickering some and tonight i was having to turn it sometimes cause they would go out.
mantisman23 is offline   Reply With Quote
Old 08-28-2010, 12:39 AM   #2
El Jay
Gone to greener pastures
Re: headlights
IF(big if) you don't have a problem downstream of the headlight switch, I'd say the problem is there because the headlight switch has the circuit breaker for the headlights.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 08-28-2010, 03:22 PM   #3
raycow
Re: headlights
It sounds like you have an intermittent short somewhere in the headlight circuit. The circuit breaker in the switch is opening and closing to prevent the wiring from burning up. There is no quick fix for this. You will just have to search for the short.
Ray
raycow is offline   Reply With Quote
Old 08-28-2010, 07:14 PM   #4
mantisman23
Re: headlights
the wiring is all completely new. I added brighter lights when i did the resto I just ordered a heavy duty harness that has relays for the lights i'm thinking this could be a fix to my problem and i will replace the light switch at the same time.
Old 08-28-2010, 07:25 PM   #5
raycow
Re: headlights
If you have higher wattage bulbs than stock, that could be causing the circuit breaker to cycle. You will know for sure once you install the relays.
Ray
Old 08-28-2010, 08:14 PM   #6
mantisman23
Re: headlights
should i just do the harness and not the switch and see if they work or just do them both at the same time?
Old 08-28-2010, 10:10 PM   #7
El Jay
Re: headlights
Put them headlights on relays & it could very well solve your problem.
Old 08-30-2010, 01:54 AM   #8
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Re: headlights
I had the same problem with on/off lights, sort of, I eventually traced it to the dimmer, swapped it out, and all was good - for $7 or so it's cheap piece of mind - especially since it kept my stock wiring headlights from working correctly at the time. I have since added the typical relay setup and h4 headlights - but it's nice knowing the dimmer will always work as well!
1969 Chevy C10 Custom Camper - "Frame On" Restoration
Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front
Beatcoaster is offline   Reply With Quote
Old 08-30-2010, 09:22 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: headlights
Always go with the easiest, cheapest possibilities first unless you know for sure what the problem is.
As mentioned above, the hi/lo switch is a good cheap fix. Lots of us have had problem with it and the light sw itself. Lt. sw has an internal rheostat that can deteriorate with age.
Check for loose connections.
Battery cables in good or new condition.
Insure you have good ground straps from all parts of the truck isolated by mounts and old rustied bolts.
Defective alternator/regulator. Easy enought to check at some auto parts stores.
68gmsee is offline   Reply With Quote
