Old 08-30-2010, 12:30 AM   #1
laid_out_70
laid_out_70's Avatar
inner tie rod compatibility?
what i have: 70 c20 with 82 c20 spindles.
ok here is my dilemma. i bought outer tie rod ends for the 82 spindles. the threads are larger on the new tie rod. i was wondering if inner 82 tie rods will fit into the ?drag link? (the rod that is in the center) so i can use 82 tie rod sleeves.
thanks in advance.
sean
laid_out_70 is offline   Reply With Quote
Old 08-30-2010, 09:16 PM   #2
laid_out_70
Re: inner tie rod compatibility?
bump. if its a no go im just going to build my own tie rod sleeves
Old 08-30-2010, 09:55 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Check the thread direction on the two tie rods.
One needs to be left hand and one needs to be right hand.
I believe what you have will be the same "thread direction".
www.performanceonline.com sells a tie rod adapter that will connect the '82 outer to you old stuff,... but you have to use '67-'70 "outer" tie rods (as inners) with your '82 outer tie rods.
Your 82 outer should be 11/16" diameter and your '70 stuff will be 5/8".
Hope this helps.
Keith
Convert to disc brakes.
Old 08-30-2010, 10:01 PM   #4
70cst
70cst's Avatar
thanks in advance.
sean
Heres a bump...Hang in there laid_out_70 and I am sure someone can offer you some help...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-30-2010, 11:50 PM   #5
basketcase
basketcase's Avatar
Hope this helps.
This is the same thing I did on my '69. The adapter sleeves and using the '70 and earlier outers as inners is the only way to fix it. It's a piece of cake once you buy the sleeves. I got mine from CPP.
When they went to disc brakes starting in '71 they made the tie rods bigger and reversed the thread direction.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 08-31-2010, 12:40 AM   #6
laid_out_70
thanks alot guys. i searched everywhere on ccp and performanceonline with no luck on finding the adapters. usually im not so useless i need a link to the exact part i need but this time i do. haha
Hope this helps.
Old 08-31-2010, 07:41 AM   #7
lolife99
lolife99's Avatar
Here you go:
http://www.performanceonline.com/196...-SLEEVES-PAIR/
Hit the "drop down" arrow.
It's part number HPAS63-70
$49.99/pair
Keith
Old 08-31-2010, 07:00 PM   #8
raycow
Is this a new build (like a disc brake conversion), or are you wanting to replace existing parts which fit properly?
Ray
raycow is offline   Reply With Quote
Old 09-04-2010, 06:07 PM   #9
xratt
xratt's Avatar
Thanks guys, just used all this info to order this part for my truck. I tried mixing and matching parts to get my truck on the road. I have a 1966 C10, I used '82 Spindles and brakes. Been driving it for about 8 months. But the steering is always giving me problems. Hope this works!!
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 09-04-2010, 07:59 PM   #10
laid_out_70
thanks guys. thats really hidden. haha. and its a new build
Ray
Old 12-09-2010, 12:01 AM   #11
laid_out_70
bumping this instead of making a new thread. i also ordered a proportional valve. ive been told mixed things about the master cylinder. will i need to get a different one? its a 70 c20 with 82 discs up front
Old 12-09-2010, 12:22 AM   #12
lolife99
lolife99's Avatar
Get a 71-72 master cylinder and proportioning valve,... Or do like I did and buy a m/c prop valve combo from performance online.
Keith
