Old 08-31-2010, 04:44 PM   #251
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Have not looked but it does have a metering block in the rear. No screws or any thing. I guess jets if i had to guess.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 08-31-2010, 04:59 PM   #252
68 TT
Still plays with trucks
68 TT's Avatar
If it has a rear metering block it has rear jets too. It just doesn't have the four corner idle mixture adjustment.
I don't know if it is as simple as just adding the correct metering block with the adjustment screws on it or not. You may want that for your final installation onto the LQ4 so you can dial in the idle mixture better. It might be worth looking into down the road.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-31-2010, 11:17 PM   #253
85burb
85burb's Avatar
I am kinda thinking the 670 is going to be a tad small for the LQ4. If it is i will get the 750cfm with no choke and 4 corner idle adjustment. It will work for now tho. It should have good response tho with all that air going threw it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-01-2010, 11:12 AM   #254
68 TT
68 TT's Avatar
You will be down on power a little on the top end but the drivability & throttle response will be better. In a heavy Suburban it is probably a better way to go.
I switched from a 600 to a 750 on my Malibu and dropped half a second in the quarter mile on back to back runs. It definitely lost some off idle throttle response and gets worse gas mileage now though.
I say keep the 670 until you are done with the build then see if you can borrow a 750 from somebody to test out before you drop the coin on another carb.
Plus side you can spend the cash you would have used on a 750 carb on other parts of the build.
Old 09-01-2010, 03:30 PM   #255
85burb
85burb's Avatar
That is pretty much my plan. Put it on and see what happens. If it falls on its face at like 4000 then i will get bigger one to try from someware not sure where tho. The interactive thing on holleys web site says 670 should do fine with slight modifiyed engine of my size.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-03-2010, 08:38 PM   #256
85burb
85burb's Avatar
So has any one found headers that will work on these trucks yet? I fainally have some money for them and a looking for options befor i order my f body headers....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-03-2010, 08:51 PM   #257
y5mgisi
Second Chance Program
y5mgisi's Avatar
Seems that street and performance (hotrodlane.cc) had some specific to our trucks.
Cant wait to see this done! Exactly what i want to do!
y5mgisi is offline   Reply With Quote
Old 09-03-2010, 10:45 PM   #258
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
there a thread of a genIII 6.0 and square body that had some headers that fit nice. not sure whether your 4x4 would be able to use the same thing though.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-03-2010, 11:00 PM   #259
85burb
85burb's Avatar
The s and p ones are 600 bucks for shortys... Way over priced..
If it is the thread i am thinking of they used f body ones. I will see if i can get a link.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-03-2010, 11:02 PM   #260
85burb
85burb's Avatar
This is where i got the idea.
http://67-72chevytrucks.com/vboard/s...d.php?t=411567
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-20-2010, 11:10 PM   #261
85burb
85burb's Avatar
Well i finally got a starter...I guess there is one under there. Not sure if i will use it or not.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-21-2010, 10:49 AM   #262
68GMCCustom
I'd certainly test it....at the least.
Kurt -
Old 09-21-2010, 11:00 AM   #263
68 TT
68 TT's Avatar
That thing is pretty ugly. I would be inclined to take it to a local rebuilder and have them clean it up and go through it to make sure everything is in good working order after the time it spent sitting out in the elements.
Old 09-22-2010, 12:08 AM   #264
85burb
85burb's Avatar
The only element i think it was sitting in is liquid. I will have it tested. The bendix part looks pretty clean tho. To say the least i was unhappy when i looked in side the box..
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-03-2010, 12:32 AM   #265
85burb
85burb's Avatar
Well i just ordered my cam Hopefully springs and lifters. Went with the Gm Hot Cam. Hope it gets here fast. Got it from SD. Wife got it for me for my birthday thats comin up fast. Just need gaskets and pushrods and headers. Also still need set of maniflods just in case.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-03-2010, 01:30 PM   #266
68GMCCustom
I'm going to have a full set of brand new p-rods left over from my 6.0 that I'm not using? Does the hot cam require hardened p-rods? Also have a set of the LY6 springs...which I'd think would be heavier duty then say a LQ4 or LQ9 due to the larger valves? Doubt they're made for much lift tho.
Kurt -
Old 10-03-2010, 06:31 PM   #267
85burb
85burb's Avatar
I dont know if it requires hardend pushrods. Its not a very big agressive cam. The cam should be coming with new matched springs with it. What length push rods did you end up going with you new cam 68gmccustom?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-04-2010, 09:50 AM   #268
68GMCCustom
haven't ordered yet but did a valve tip swipe and it looked like the stock length was going to be OK...then I did a zero lash check this weekend and came up with a figure of roughly -.125 difference in my adj. p-rod, and the stock p-rod. I need to check with my expert and see if thats about the right preload or not.
Kurt -
Old 10-04-2010, 11:27 PM   #269
85burb
85burb's Avatar
Ok thanks for the info. I may pull my heads this week end and find a shop to check them. Hope there is no problems with my cylinder boars. Have no idea how long the thing has sat. And my dang warrenty is already up on it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-04-2010, 11:32 PM   #270
68GMCCustom
somthing I'd have done to mine had I know it was going to sit this long....pull the p-rods. Not only does it give the springs a break...it keeps all the valves shut to keep moisture from rusting the valve seats and keeps from allowing moisture into the cylinder.
Kurt -
Old 10-04-2010, 11:52 PM   #271
85burb
85burb's Avatar
I know i should have done that. Used to do it to our race car every week. Used to back off rockers. It had a massive lift cam. Prety sure it was a 740 lift cam. Good thing i am tossing the old springs. Are you using the factory rockers? I am not real sure how to adjust the valves. I beleve they are not adjustable but have not played around with them yet.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-04-2010, 11:54 PM   #272
85burb
85burb's Avatar
Does it really mater if i mount my fuel pump a little higher then the bottom of the tank. There is no good place to put the big ass thing. And the dand inlet and outlet is on the wronge sides. If i mount it on inside of the passenger side the inlet is twards the front and out is at the back. Any ideas?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-05-2010, 09:59 AM   #273
68GMCCustom
I know...mount it upside down!
with the LSx and all....what would it look like if you were to run you fuel line on the other side of the frame?
Kurt -
Old 10-05-2010, 09:16 PM   #274
85burb
85burb's Avatar
Can they be mounted upside down? Thoght about that but i will be putting it in befor the motor.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-05-2010, 09:50 PM   #275
68GMCCustom
I was j/k!
Kurt -
