09-01-2010, 06:46 AM | #26 |
A320 Pilot/USAF Retired
Re: '51 new IFS installation
Looks great! Lets see some shots of the completed setup when you return.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
09-01-2010, 09:41 PM | #27 |
Looks real nice, I'm using the Progressive Automotive setup. I was wondering, whats the distance from the tip of the frame to the axle center line? Mine is 20 3/4 stock.
09-02-2010, 03:19 PM | #28 |
Very Nice!
01-12-2011, 12:05 AM | #29 |
01-12-2011, 03:03 AM | #30 |
Nice looking kit,stance and installation, bet it'll handle like a slot car now!
Well.. compared to the original solid axle...... |
01-12-2011, 11:54 AM | #31 |
Thanks! Being my first project, there was quite a bit of hand wringing before cutting the frame, but the guys at Flat-Out were very helpful. I'm really pleased with the results.
01-12-2011, 11:46 PM | #32 | |
Here is what we ended up with after doing a lot of homework, it is from Scotts Hot Rod. Thanks for your help with this decision process
01-15-2011, 08:38 PM | #33 |
That Corvette setup looks very clean and well thought out. Nice job on the installation too. The thing I like about that Flatout setup is that everything except the crossmember and coilovers are factory parts and replacements shouldn't be an issue down the road.
Well, maybe next winter you can do the rear in a like fashion. |
04-25-2011, 12:43 AM | #34 | |
How much did scotts kit cost after everything. That looks even better!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
04-25-2011, 06:37 AM | #35 |
Yellow truck club
go up about 4 posts from yours and he has a price list.....
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
04-25-2011, 07:42 AM | #36 |
What year is the Corvette stuff? Is it junkyard stuff?
04-25-2011, 12:18 PM | #37 |
The donor was an '86, I bought it from Craig's list. (The seller was in the process of rebuilding when his shop collapsed and crushed the disassembled car.) I've seen them on Ebay for anywhere between $400 and $1000. There are different versions of the kit for any of the C4s.
04-25-2011, 01:28 PM | #38 |
Thanks but the prices listed is for the Flat out kit. Scotts kit is different. full adjustable control arms and a sway bar.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 Last edited by nebdrummer; 04-25-2011 at 01:29 PM. |
04-27-2011, 01:35 PM | #39 |
nice
Doug Looking for a 67-72 short bed driver..... |
04-29-2011, 01:08 AM | #40 |
bmac
do you have any picks of the completed front install without the front clip on? thanks Rafael |
06-03-2012, 10:41 AM | #41 |
Bmacdona, I am looking at your pictures of the Flat Out Engineering cross member that you installed and from the pictures I cannot figure out how it was installed. Was the cross member installed to the outside of the frame as the cross member is a one piece unit and then a spacer installed in the inside of the frame rail for support or was the frame modified to accept the cross member. Also I could not see if you “C” notched the frame for clearance for the steering tie rods like Progressive does on their kit. I have a 52 AD with a Pacer front end that I want to replace it and trying to determine whether to go with the Flat Out Engineering kit or Progressive kit. Thanks
06-03-2012, 01:35 PM | #42 |
Gabby,
The outside of the frame is notched and the crossmember slides into position, (well....not slides, needed some persuasion)...the frame is c-notched for the steering rack and they supply a formed piece to fill/reinforce the cutout. Last edited by bmacdona; 06-03-2012 at 01:45 PM. |
