Old 09-01-2010, 02:01 PM   #1
Cbrown67
anyone ever fill in all the factory open holes on the frame?
pics if so?
Cbrown67 is offline   Reply With Quote
Old 09-01-2010, 02:35 PM   #2
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: anyone ever fill in all the factory open holes on the frame?
I filled in one. I cut a plate of steel (same thickness as the frame) to fit the hole. Welded it in and ground the welds down with a 4" grinder, then painted it. You can't tell the difference. What's your purpose?
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 09-01-2010, 03:50 PM   #3
Cbrown67
cleaner look i was just toying with the idea i have a lifted truck and it has a 3 inch body lift so you see a good amount of the frame
Old 09-01-2010, 04:51 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
On my 76 I have filled in some holes and I am planning on putting some plates to hide the open area under the box due to the body lift. We'll see how it goes.
Ryan
1969 Chevy milk truck
Old 09-01-2010, 04:52 PM   #5
69sixpackbee
I just fill the holes with weld buildup and grind them flush. Wire-feed MIG works best for this. I can fill big holes without any trouble.
69sixpackbee is offline   Reply With Quote
Old 09-01-2010, 04:57 PM   #6
Cbrown67
thats what i was going to do mig weld build up just didnt knwo if people did it and they are upset that they did
Old 09-01-2010, 05:04 PM   #7
Dieselwrencher
Honestly, I prefer a frame that is clean looking without a bunch of unused holes. The only reason I would be upset, is if I screwed up and filled some holes i actually needed.
Ryan
Old 09-01-2010, 05:07 PM   #8
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
I will deffinatley be filling all unused holes when I tear the truck down...
No need to box it in but I don't like un needed holes
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 09-01-2010, 06:31 PM   #9
gkesseru
gkesseru's Avatar
I have always heard that frames are annealed and tempered to be stronger than just plain bent steel. If that's true, then unnecessary welding will weaken the frame, not strengthen. Is this true?
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 09-01-2010, 06:34 PM   #10
69sixpackbee
Don't really think so. I can drill through them no problem. Besides, when you are filling holes you are not concentrating that much heat in a vast area. Just one small hole at a time.
Old 09-01-2010, 06:39 PM   #11
gixxerpymp
Not worth it if your frame sits on the ground...
gixxerpymp is offline   Reply With Quote
Old 09-01-2010, 06:50 PM   #12
Hezie
Hezie's Avatar
Find a metal fab shop and have them punch you some plugs with an iron worker. I used 1/2 and 3/4 drill out the holes to the next larger size and weld in the plugs.I will look for pic's. By the way there are lots of them.
Hezie
My Build
http://67-72chevytrucks.com/vboard/s...d.php?t=375244
Hezie is offline   Reply With Quote
Old 09-01-2010, 06:51 PM   #13
Hezie
Hezie's Avatar
Yea... I did that
Hezie
My Build
Old 09-01-2010, 07:38 PM   #14
Notrodder
Doing so is sacrificing structural integrity for the sake of appearance. I don't know the composition of these frames, but they are better than mild steel.
When you weld an alloy using mild steel filler (wire feed) the alloying elements migrate to the edge of the weld puddle. The results are a comparatively soft weld with a line of harder metal immediately adjacent to the weld. This point will be the week spot in the frame and will be the area to buckle and/or crack when subject to stresses that the unmolested factory frame may or may not have been able the handle.
This is why the repair inevitably fails when the average dork trys to fix his chromoly-steel motorcycle frame with a wirefeed.
If you really must fill the holes, at least go the mile and find out what kind of metal you are dealing with and do the welding with a heli-arc and the appropriate filler rod.
Notrodder is offline   Reply With Quote
Old 09-01-2010, 07:38 PM   #15
Dieselwrencher
They say the same thing about semi frames. Guess what, how do they repair them? You heat them with a torch or multiple torches while you have a frame machine maxxed out pulling the frame where it needs to be. And then those wrecked trucks are returned to service and continue with life.
Ryan
Old 09-01-2010, 07:59 PM   #16
Notrodder
^ That is reasonable frame repair, but if someone had done some bad welding on the frame before the accident the truck would not have been worth fixing.
Old 09-01-2010, 09:20 PM   #17
Dieselwrencher
True. Good point. However, I still wouldn't be afraid of filling holes in any of my projects. But that is me.
Ryan
Old 09-02-2010, 09:25 AM   #18
Cbrown67
thanks for your thoguhts guys!
