Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-02-2010, 04:21 PM   #1
67chevy2wd
67chevy2wd's Avatar
Took the 71 GMC out and messed around some.
Time for a bigger lift. It is sitting on stock springs with 3" blocks front and rear. I know front blocks are bad but that is how it came. Will bigger lift springs help with the frame twist?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 09-02-2010, 07:45 PM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Took the 71 GMC out and messed around some.
i HIGHLY doubt it will. boxed frame or added cross-members will help.
other than the front blocks you got a good looking truck
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-03-2010, 04:07 PM   #3
67chevy2wd
67chevy2wd's Avatar
The plan is to install a proper lift this fall if I can afford it. I want to do a lift, tires, 4.56 gears and lockers front and rear. That is my future plans.
'71 GMC 3/4 ton 4x4
Old 09-22-2010, 08:36 PM   #4
silver7
silver7's Avatar
A good set of fresh lift springs in the front and back will do your truck good. Keep a look on Craigslist - you can often finds guys who started projects offering good deals on newer springs.
But you'll need to build up your frame to stop the twist.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
