09-02-2010, 07:02 PM | #326 | |
Re: LS1 into a 73 cheyenne
Thanks for the valuable info. can you send me a link of that ebay auction.
09-02-2010, 07:18 PM | #327 | |
Still plays with trucks
http://cgi.ebay.com/ebaymotors/1998-...item3cb070e88b His ad is wrong. They are 12" diameter x 1" thick rear rotors not 11". You could always get this instead http://cgi.ebay.com/ebaymotors/04-Po...item53e22ba9a5
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-02-2010, 07:21 PM | #328 |
Here is another one for only $125
http://cgi.ebay.com/ebaymotors/1998-...item1e5e112f79 He will even knock $20 off if you don't want the old rotors. Pick up some nice cross drilled ones to use instead.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 09-02-2010 at 07:23 PM. |
09-02-2010, 07:27 PM | #329 |
What will it take to install these as far as fabin a braket or modifying an existing braket, maybe a weld on braket . there off a 09 Chevrolet Corvette ZR1 Brake Caliper SET OEM
09-02-2010, 08:12 PM | #330 |
98-02 Camaro to Corvette C5 brake conversion brackets wonder if this will work on a c6
09-02-2010, 11:41 PM | #331 |
where did you find those brake conversion brackets?
09-02-2010, 11:52 PM | #333 |
i found them on ebay heres a link http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
i askd him if they would work on C6 calipers and this was his reply quote - C6 cal. will bolt to these. The c6 rear cal. will bolt to the stock Fbody abutment. You dont need a sp. brk.b Dale Last edited by smokedat; 09-02-2010 at 11:53 PM. |
09-03-2010, 12:02 AM | #334 |
found some more pictures of these conversion brakets
09-03-2010, 09:44 AM | #335 |
I was thinking about maybe upgrading my McGaughy F & R kits by using the 2010 SS Camaro/Brembo calipers. There 4 piston and I think I could build a bracket to work properly.
09-03-2010, 12:11 PM | #336 |
09-03-2010, 01:50 PM | #337 | |
A little quality time with a spare spindle & rotor and a mill / lathe is all you need. The third gen F-body guys cut off the stock caliper brackets and use the dust shield mounting bolt points as caliper mount points. You may be able to do the same or even use the old caliper mount bolt holes to hold the caliper bracket for the 09 Vette parts.
09-04-2010, 09:28 AM | #338 | |
Happy to be here
The difference being is those kits us stock rotors. The McGaughy kit is the only "reasonable" priced kit on the market that runs 13" rotors F&R.
Niped- Have you read this post? "Just bought some calipers, any ideas if I can make them fit?" Quote:
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-04-2010 at 09:38 AM. |
09-04-2010, 02:17 PM | #339 | |
09-05-2010, 06:23 PM | #340 |
i got the tires in on saturday these things are massive still waiting on the wheels here are a few pics
09-05-2010, 08:18 PM | #342 |
Kvn1011
DAAAAAAAAAAAAYUM!!!!!!!
Posted via Mobile Device |
09-05-2010, 08:38 PM | #343 |
WOW very nice build I just love it great work man.
09-07-2010, 12:37 AM | #344 |
This truck is gonna be amazing
Drive It Like Ya Stole It '82 Primer White c10 2wd LWB 350 sbc t350 (Hot Rod) '90 2wd LWB Silverado 350 tbi 700R4 (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
09-07-2010, 01:01 AM | #345 |
awesome build
09-07-2010, 08:20 PM | #346 |
the rear is off
09-07-2010, 08:25 PM | #347 |
also finishd muding andspraying the interior of the cab. I shaved all of the ulphostery trim holes, sun visors and upper seat belt holes. It will all be painted and left exposed
09-07-2010, 08:29 PM | #348 |
also finished the radiator support, upper holes and bettery tray holes and ac heater holes were shaved. The extruding lip around the radiator was cut. I slaped on sum POR 15 on the bottom face
09-07-2010, 08:37 PM | #349 |
To shave the cab seam i used sum 3M 3M 8115 PANEL BONDING ADHESIVE then i used a die grinder to sand it flat, this method is by far the fastest and its just as strong as a weld. The only problem is that this panel glue absorbs paint to prevent this i over sanded then i will apply a thin layer of either body filler or glaze.
09-07-2010, 08:43 PM | #350 |
as far as mudding goes the roof is the last of it. First layer shown here, still needs more work
Tags |
73c10, c10, cheyenne, ls1, swap |
