Old 09-03-2010, 10:21 AM   #1
ldgn63
simple solution for controlling rear bags?
maybe this should be in "suspension" forum???
Im leaning towards putting bags on the back of my ’67. I don’t wanna hop, skip, or jump with it… just get about 5 to 6” drop in the rear and be able to pressure up for loads… and maybe drop to the frame to load objects (motorcycle, etc) in the bed. I DO want it to be SAFE!
I will probably start out with Schrader valves for simplicity and to see if I really like the bags better than springs. (thinking of Firestone 2600’s or equiv.)
For future plans I am wondering if anyone has used a system like in the link for running simple air bags as the only support for the rear? Without a tank and lift/dump valves etc.
I could always just mount a compressor and a switch and some air hose to fill the schraders but having control in the cab seems much nicer!
Thanks!
Amazon.com: AIR LIFT 25592 Load Controller II On... Amazon.com: AIR LIFT 25592 Load Controller II On...
Amazon.com: Firestone 2178 Dual Gauge Ld... Amazon.com: Firestone 2178 Dual Gauge Ld...
ldgn63 is offline   Reply With Quote
Old 09-03-2010, 11:33 AM   #2
Street Lethal '72
Street Lethal '72's Avatar
Re: simple solution for controlling rear bags?
I just bought a 72 where the guy did just that.. Firestone bags and a Schrader valve.. unfortunately something failed on the way home with it.. but if done correctly, what you suggest sounds fine. He put a valve solenoid on it to drop it, wired to a simple rocker switch. But, in his set up (now mine, but going away soon), you have to hit the switch, then manually press the schrader to deflate.. I guess he planned on switches at some point. In your case you can avoid the valve solenoid thing, and just use the schrader. We had a 77 F150 with simple air shocks and a schrader, worked for many years to haul an in bed camper.
I will say, while I was driving the 72, it drove like a new car on those bags.
Street Lethal '72 is offline   Reply With Quote
Old 09-03-2010, 01:10 PM   #3
ldgn63
thanks.
at first i'll run schraders and probably carry a battery (or lighter) operated air source... I roll redneck!
wonderif if someone has run something like the links above too?
Old 09-03-2010, 02:00 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
just to give you an Idea becasue when I asked I could never get the answer I run about
35/40 lbs in rear
I have no compressor but a 3 gal air tank will lift the REAR a couple times and the front once ( keep in mind its lifting a 500 caddy) on the cheap ( you roll redneck I'm border Gheto) yes you can just run just schraders...also when you goto wire up solinoids use flat 4 trailer wire....you need 2 wire for each corner ( up and down) so the flat 4 makes wireing them up the the front a breeze.....gheto or just smart?? you decide
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-03-2010, 02:09 PM   #5
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Im running this kit from ECE...works great.
-Ron-
OldSkool71 is offline   Reply With Quote
Old 09-03-2010, 03:03 PM   #6
ldgn63
thanks guys.... very much obliged!
Old 09-03-2010, 03:39 PM   #7
epashhans
epashhans's Avatar
Hey OldSkool71, do you have a number on that system or what its called?
Thanks!
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 09-03-2010, 03:40 PM   #8
epashhans
epashhans's Avatar
Nevermind, found it!
http://www.earlyclassic.com/catalog.aspx
Old 09-03-2010, 04:05 PM   #9
6772owner
Gearhead
6772owner's Avatar
I have had that ECE rear kit (minus compressor system) for probably 5-6 years now and never had a single problem. I just have schrader valves (were mounted in the rear, now I have them in the cab) and use an Airlift compressor with a 1 gal tank. I ran the tank line into the cab and have all four air bag lines and the fill line in a center console. I can dump/fill the bags' from inside the truck and have a switch on the pressure switch to turn off the compressor if needed. (And you thought you were redneck!!)
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-03-2010, 04:57 PM   #10
ldgn63
i'd love to see a pic of THAT setup... totally sounds like something i would do!
Old 09-03-2010, 04:58 PM   #11
ldgn63
what bags are on that ECE kit?
Old 09-03-2010, 05:44 PM   #12
6772owner
Gearhead
6772owner's Avatar
Ok there are plenty of detailed pics of the my entire set-up in my build thread, but heres a pic of the current center "console" set-up I have.
The ECE bags are Firestone, plenty heavy for all the payload I have ever had.
