Old 09-04-2010, 12:25 AM   #1
RAWDOGG
Hello....new to the board and new to owning a C-10
I just traded a 92 camry I was using as a commuter car for a good running somewhat rough looking 1971 C-10. I plan to pull the body and do a frame off, which I have never done before.....i would like to ultimately bag it, but not sure how soon that will happen as I don't have the experience nor tools to "c" notch it, so I might for the interim put a nice lower kt on it, while I go through everything else.....Any recommendations on orders of magnitude? i think i want to tclean and sand off the original paint and clean up the minor dents then primer it. Is it advisable to remove all body parts and sand/clean then spray outside/inside with a quality primer? Any thoughts/advice/insight would be greatly appreciated!
RAWDOGG is offline   Reply With Quote
Old 09-04-2010, 12:36 AM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Hello....new to the board and new to owning a C-10
You've got a long way to go before you have to worry about primer. Unless you plan to do things twice, spraying a good primer and then leaving it is not a good idea unless you plan to leave it indoors.
Take lots of pictures, store parts in labeled plastic bags, buy an assembly manual, and spend every waking moment reading the suspension, paint, and build forums.
Welcome!
Zoomin is offline   Reply With Quote
Old 09-04-2010, 07:37 AM   #3
68Stepbed
68Stepbed's Avatar
Welcome to the board from east TN!
My suggestion is keep things simple for now until you learn the ins and outs of the truck. To start with, make sure your engine, drivetrain, and suspension are in good condition. I would keep it a driver for at least a year or two. Lower it, put a nice set of wheels/tires on it, and drive it. Learn the truck how it is now, then look at upgrading or changing things.
If this is your first go around with this sort of thing, don't plan on a full frame-off resto. It gets expensive, time consuming, and it's very easy to get discouraged.
Drive and enjoy the truck as long as you can until you just HAVE to do a frame-off. Try to find some other board members in your area and hook up with them for advice and/or help. Don't be afraid to ask questions. We're a pretty group of guys here and are very willing to help out another truck brother. There's no such thing as a stupid question around here, so ask away and get answers you need.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-04-2010, 08:02 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Thanks for the compliment.
What they are telling you is good advice.It worked so well for me that I now do a mod in the fall/winter and drive mine the rest of the time.Sure it's a slow go on the resto but i get to enjoy the driveing and still work on it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-04-2010, 08:09 AM   #5
srea76
srea76's Avatar
Welcome to the boards. I would advise you to do things to it for the time being that allow you to keep driving it also. I have 2 friends that got trucks about the same time as me. They tore them down working on them and got frustrated and gave up. Keeping it drivable while you work on it will always allow you to jump in and put some wind in your hair until you actually get ready for the ground up. That will be expensive. If you can save parts and money before you start that.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 09-04-2010, 09:06 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
Welcome from Southeast Missouri.
I agree with everything above. I try not to have my trucks down for a very long time because I do enjoy driving them so much. One has a L6 and the other a 454, both are fun to drive, of course in different ways.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-04-2010, 12:33 PM   #7
RAWDOGG
Thanks for all the advice! All of you made some very solid points...Ithink for the time being I will keep the truck driveable and modify/upgrade on the weekends....What brand of assembly manual do you suggest?
Old 09-04-2010, 12:54 PM   #8
barryvanhook
barryvanhook's Avatar
Wise decision to drive it and go at it piecemeal ... I've seen too many "frame-off" restorations end up as "pile of parts" sales when the owner felt overwhelmed and frustrated.
Barry
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
Old 09-04-2010, 12:55 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Barry
You took the words right out of my mouth.
Welcome to the board Rawdogg...I am just up the I 15 from you.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-04-2010, 02:00 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board from southern oregon....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-04-2010, 02:08 PM   #11
gsxrdoug
1970 C10 six
gsxrdoug's Avatar
Welcome aboard lots of knowledge on this site, enjoy.
1970 C10 L6 250 three speeder
gsxrdoug is offline   Reply With Quote
