Sub Rear Bumper
Need a bumper for my 1960 GMC Suburban [rear]. I know that none are made specificaly for the sub but what are you guys using? I'm thinking that a Fleetside bumper might work but I thought I'd throw it out here first. Will the Fleetside width be the same as the sub? Fabbing brackets not a problem.
Thanks Bob |
![]() Join Date: Aug 2005
Re: Sub Rear Bumper
Isn't the sub rear bumper the same stamp as the front bumpers with different holes?
1961 crewcab
Re: Sub Rear Bumper
yep
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
60-66 Nut
Re: Sub Rear Bumper
Yes the Suburban rear bumpers are basically the same as the front bumpers. The difference is in the location of the mounting holes since the rear of the frame is wider than the front. On the '63-'66 2wd Suburbans the rear bumper has a mounting bolt dimension of 32" center to center, and the front is 26 1/4" center to center. The '60-'62 2wd Suburban frames are wider just as the pickups are, but I don't have those dimensions handy. I believe the '60-'62 Suburbans use a bolt on bracket to mount the rear bumper. I may be able to get a pic of that bracket tomorrow.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-05-2010 at 12:57 AM. |
Re: Sub Rear Bumper
The fleetside bumper has the notch for the license plate, which the Suburbans and panels don't have.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Re: Sub Rear Bumper
pu bumper will not work properly due to the dip as the sheet metal on the rear of a sub or panel is higher than the dip and the sheet metal has a rubber seal along that edge
ron |
1961 crewcab
Re: Sub Rear Bumper
here are some decent shots of rear sub bumps...
first three are 60-62, notice how far outboard the bolt holes are. last one is a 63-66 notice the bolt holes are farther in. sub rears and front bumpers have a little crown to them, wheras a fleet rear is basically flat. you could probably get away with hanging a front on there until you find the correct sub/panel rear. would just either have to drill some holes or fab up some custom brackets..
60-66 Nut
Re: Sub Rear Bumper
Here are a couple of pics of the mounting brackets on a rear bumper for a '60-'62 Suburban/Panel. I got sidetracked and didn't get a measurement on the bolt spacing. I'll try and get those dimensions tomorrow.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-06-2010 at 12:38 AM. |
Re: Sub Rear Bumper
I think I'll try to hang a front bumper with fabbed brackets and see how that looks. I'm aware of the step in the Fleetside bumpers and can'i decide whether that would stop me from buying one..Thanks all for the help and pics especially helpful..
Bob |
60-66 Nut
Re: Sub Rear Bumper
OK. the bolt spacing on the '60-'62 Suburban/Panel rear bumpers is 44 1/2" center to center.
Post some pics when you get something fabbed up Big Fenders.
Re: Sub Rear Bumper
im looking for front and rear bumpers for a 66 chevy truck, paintable
1960 GMC Burb
Re: Sub Rear Bumper
You can always look at my 60 to measure/match what you need.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() |
Re: Sub Rear Bumper
Uh....Let get back to the Purple Sub for a moment. There seems to be some sort of blockage of sorts to see the entire bumoer. Good Blockage though
http://s1299.photobucket.com/user/jb...23904108567829 |
#14 | |
1960 GMC Burb
Re: Sub Rear Bumper
#15 |
![]() Join Date: Aug 2004
Re: Sub Rear Bumper
I personally liked the denim bumper, although it isnt easy to see, it sure looked good tho.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
