Old 09-05-2010, 10:05 PM   #1
gmclowsierra
axle locating device
im going to build a 2 link for my 85 gmc. i already have the links from the factory hangers to the rear built, im looking for info on a locating device. i really dont want to a panhard bar due to the axle moving side to side when my bags are deflated and inflated. i cant afford to buy the kp components watts link for my truck, so i was wondering if i would run braces to x out my links that i have if that will hold the axle side to side? Thanks for the help. JOE
gmclowsierra is offline   Reply With Quote
Old 09-05-2010, 10:36 PM   #2
texastrendz
Re: axle locating device
pan hard bar, just make it long.
texastrendz is offline   Reply With Quote
Old 09-05-2010, 10:53 PM   #3
ccreddell
ccreddell's Avatar
+1
ccreddell is offline   Reply With Quote
Old 09-06-2010, 08:55 AM   #4
Shane
Shane's Avatar
For the safety of everyone else on the road when you are, please add a Panhard bar.
Shane is offline   Reply With Quote
Old 09-06-2010, 10:04 AM   #5
gmclowsierra
thats fine if i have to do that but you dont think that the x would work
Old 09-06-2010, 10:56 AM   #6
bedsled71
bedsled71's Avatar
use a trac bar
bedsled71 is offline   Reply With Quote
Old 09-06-2010, 11:01 AM   #7
bedsled71
bedsled71's Avatar
its a rod with heims at both ends. one end mounts at the front of one link and the end at the end of the other link.. it triangulates your bars to eliminate latteral movement
Old 09-06-2010, 12:40 PM   #8
texastrendz
most people use a pan hard bar on a two link. i did use a track bar on my triangulated 4 link because of all the flex in the bushings. it tightened it right up. i never have used a track bar on a two link, seems like it would work.
Old 09-06-2010, 02:02 PM   #9
ccreddell
ccreddell's Avatar
A track bar will work in theory, but logistically, seeing as how most two bars use the forward leaf spring hanger, you may run into interference with the frame, the driveshaft, or both.
Old 09-06-2010, 02:58 PM   #10
gmclowsierra
thats what my theory was to use a track bar or actually two track bars and cross them like an x. instead of using bars with hiems i was going to use something liike 1 inch box tubing and just weld everything together.
Old 09-06-2010, 04:21 PM   #11
SCOTI
SCOTI's Avatar
Solid mounting of an 'x' brace between the lower links sounds like a recipe for stress failure.
How much travel are you planning to have? A long Panhard bar will suitably locate the axle w/o much issue. Many vehicles on air from this forum & in the real world use them successfully.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-06-2010, 08:30 PM   #12
gmclowsierra
im going to mount my bags apporimatly 8 inches back on the bar. i have 2500# bags on the rear so im guessing 8 maybe 10 inches of travel. im not afraid of using the panhard rod im just looking for other ideas. basically im building the same kit as extensive metalworks just without the giant notch
Old 09-06-2010, 09:30 PM   #13
dropd80s
dropd80s's Avatar
X2 would not suggest welding it in like that.
dropd80s is offline   Reply With Quote
Old 09-06-2010, 10:31 PM   #14
ccreddell
ccreddell's Avatar
If clearances are not an issue, then this would be my next concern. Use heim joints or rubber bushings if you decide to go this way. And keep in mind you really only need one angled brace-two is over complicating things. The other thing to remember is that your rear wheels dont go up and down together like a swing arm on a bike, they move up and down independently, so the stiffer you make the assembly the more things it has to bend to achieve tire contact-which is what Scoti is referring to above. Also, the stiffer it is, the more it acts like a REALLY big sway bar and it will cause the rear end to swap on you without (much) provocation.
Old 09-08-2010, 08:59 PM   #15
bedsled71
bedsled71's Avatar
track bar track bar track bar
Old 09-08-2010, 09:01 PM   #16
bedsled71
bedsled71's Avatar
http://67-72chevytrucks.com/vboard/s....php?p=2640630
post # 47 and 49
Old 09-08-2010, 09:11 PM   #17
bedsled71
bedsled71's Avatar
before i did the back half i had a 2link from the stock hangers so it will work. just do the obvious and check clearance before welding the tabs with the driveshaft in and set at the right pinion angle
