has anyone put 03 silverado seats in a 73-87 chevy?
just got a smoking deal on a set of 03 crew cab seats and wanted to see if there is a thread about putting them in a 73-87 truck on here. i know there was one but i cant find it.
Next project: 1970 K10
Re: has anyone put 03 silverado seats in a 73-87 chevy?
I put a set of late 90's seats in mine, very close to the same seat. I also put a set of 04 seats in my 68.
The 90's ones I put in my 85 I pulled all the OEM slide track stuff off and scratch built a frame from 1" square tubing. The 04's that I put in the 68 I used the OEM tracks and mounts, and just drilled new holes in the floor. I had a shim up the center mounts to make everything level, but it was pretty easy. The ones in the 85: The 68, poor pic, but the only one I have here at home:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
BMW & ASE Master Certified
i put the 99+ silverado seats in my 87.. used the 87 slider with some 1.5 square tubing stock and made my own brackets... still havent came across a center console but the fit is great... im 6'6" and got plenty of room. I dont have the recline feature but its still good.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#4 | ||
noooooooooo!!!!!!!!!!!! why put those ugly seats in there!
1979 GMC Sierra Classic Freshly lowered 5 inches ![]() ![]() |
BAD BOW-Silverado XST
I have diagrams for a mounting bracket. You can mount any seats you want. The frame bolts directly to the stock locations. Let me dig it up.
I don't know if this will help or not. I put a 60/40 bench seat from a 92 CC in my 79. HERE is a link with pick of how I mounted it.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
I'd like to see this
I don't think the OP is asking for opinions...he is asking how to do it.
#10 | |
I put early 90's Ford windstar seats in mine. Think outside the box. However, I am now looking for low back leather buckets. Lots of mini vans had nice seats.
PO put a set of '05 seats in mine. They used a couple of pieces of flat strap steel across the floor to mount them in the front. distance to the pedals and wheel is good (I'm 6'2") but the seats sit a bit high, so I'm looking out the top of the windshield even with my usual "detroit lean" seating position.
Back seat isn't attached to the floor yet, but they did put a strap steal brace across the back of the cab that the rear seat is mounted to. I'm considering replacing it with either stock seat or doing a pair of the same front buckets in the back (because I wan't shoulder restraints for my kids in the back).
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
Hulk,
Do you have any pics of how they are mounted? I'm wanting to mount some '05 seats in my crew. Posted via Mobile Device
I'll try to grab a picture later today and post.
#15 | |
#16 |
the way i want them to sit i dont see how it would work without cutting the floor out unless you dont need the recline option and the oem rails. wich im using and i dont mind cutting the floor. by cutting the floor in the front i should gain some more leg room in the rear anyways.
#17 | |
#18 |
heres some pics of them just sitting in the truck
#19 |
Same seat I've got. I'll post those pics in the morning. Ended up working later than expected and then had to hassle with some racoons so I didn't get out to the truck with the camera.
#20 |
I am wanting to do the same thing! I would like to see these installed...
#21 |
OK, here ya go. I didn't do it and probably would have cut the floor if I had, but it's not really all that bad, especially since I generally drive in a more reclined seating position. Oh yah, I will take responsibility for the Kustom recline lever though...
#22 |
So they just used a piece of flat stock steel across the front and back? Hmm I kinda like that idea.
#23 |
did u have to drop the gas tank to bolt down the steel?
![]() All that I am, I owe 62SWB-STEP 83SWB 86LWB |
#24 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
You wont like it when you get rear ended and wind up ass over apple cart in the back of the truck!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#25 | |
