Old 07-16-2010, 08:10 PM   #276
JML55
JML55's Avatar
Re: 55 2nd serie GMC
At a stand still with the paint job, well actually going backward. The paint job on the cab didn't turn out at all the way i was looking for. After trying to fix the orange peel issues i found the paint was lifting at a few places. So here i am blasting the paint of the cab again and starting all over.
JML55 is offline   Reply With Quote
Old 07-16-2010, 09:11 PM   #277
Kabwe
Certified Car Nut
Kabwe's Avatar
sorry to hear that man.
Kabwe is offline   Reply With Quote
Old 07-28-2010, 04:44 PM   #278
ambryatim
ambryatim's Avatar
http://67-72chevytrucks.com/vboard/s...2&postcount=83
Did you have any issues with getting the engine level from side to side?? I did some research on those mounts (for the older camaro's) and they are different heights or did you order 2 of the same one??
ambryatim is offline   Reply With Quote
Old 07-28-2010, 07:23 PM   #279
JML55
JML55's Avatar
The side to side was an issue, i don't have any pictures but i did modified those Camaro mounts a lot, well until the fitted right. I cut them down about 1/2 inch if i remember good. I centered the engine without mounts measured the distance between the bloc mounts and cross-member and cut the frame mount to fit.
Old 07-28-2010, 09:49 PM   #280
ambryatim
ambryatim's Avatar
Ok, thanks. I was hoping it was going to be more straight forward, but since you had to modify them "alot" then I will just build my own like I was planning to do.
Old 08-22-2010, 10:47 PM   #281
JML55
JML55's Avatar
Very little done on the truck since the flop with the paint job. I'm trying to decide if i redo it myself or if i find someone else to redo the body work and then paint it myself. Reworked the back bumper this past weekend. My first one was very rusted on the ends. Had to use two bumper to make one that was decent , i used the ends of one and the center of the other one and cut in a license plate. I'm also reworking the front bumper a little, pics to come.
Old 08-23-2010, 03:00 AM   #282
Woodbutcher
Woodbutcher's Avatar
I have to say, JML55, that I am enjoying your buid thread tremendiously. It was a way to spend an evening reading about your truck. It's been a long road, the effort is outstanding and the results are speaking for themselves. Persevere and you will have one sick looking ride when you are done!
Curious though, what shade of green did you choose??
I have yet to start a build thread on my 56 Chevy but will post tons of pics as I appreciate all the pics on this site.
Woodbutcher is offline   Reply With Quote
Old 08-23-2010, 07:12 AM   #283
JML55
JML55's Avatar
Thanks Woodbutcher, It's the New Camaro green, I'm thinking something a little different for the second time around.
Old 09-05-2010, 06:47 PM   #284
JML55
JML55's Avatar
Worked on the front bumper mods this weekend. I though it would be fairly simple mod but it turn out to be a bit of work. Here is before and after pics, can you see what is different?
Old 09-05-2010, 11:06 PM   #285
ambryatim
ambryatim's Avatar
Looks like you installed something inside the bullets?? Maybe a baby moon hub cap?? But, there is an insert of some kind.
Looks really good too, what ever it is.
Old 09-05-2010, 11:21 PM   #286
bobinbc
bobinbc's Avatar
That is a beautiful grill, Jean-Marc. Did you modify the bullets?
Edit: oops ambryatim beat me to it
1957 Chevy black 1420 LBSS
1955 Chevy green 1300 SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 09-06-2010, 12:57 AM   #287
Kim57
Kim57's Avatar
Looks sharp.
Kim
Kim57 is offline   Reply With Quote
Old 09-06-2010, 01:58 AM   #288
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
I like it, is the mesh behind the GMC letters stock?
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 09-06-2010, 09:20 AM   #289
JML55
JML55's Avatar
Tri5
No, it never had a mesh in there from the factory and the GMC script would have been on the front of the hood.
Old 09-06-2010, 04:30 PM   #290
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
I'm kinda do'n the same thing to my grill, do you happen to have a pic of the back of your assembly? How'd you mount the mesh to the grill? Weld tabs on?
Cameron Gunlock
Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750
addicted2dunes is offline   Reply With Quote
Old 09-06-2010, 08:04 PM   #291
Tri5Nerd
Tri5Nerd's Avatar
That's what I wanted to hear. , Now I would like to know where you got the mesh from, cause I can't find any that would work for me.
Tri5
Old 09-06-2010, 08:31 PM   #292
GRIMSS
GRIMSS's Avatar
Tri5
I have a catalog from McNichols Co. that has something like that.
www.mcnichols.com
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 09-06-2010, 09:29 PM   #293
Coronas56
Coronas56's Avatar
Looks Like you're using 57 Gmc Bumper bullets.........
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 09-06-2010, 09:57 PM   #294
JML55
JML55's Avatar
You're the winner.
Old 09-06-2010, 10:10 PM   #295
JML55
JML55's Avatar
This is an old exhaust stack shield from a big rig i had kinking around the shop. It's attached to the filler panel that is between the bullets at the bottom and to the under edge of the cross over bar.
Old 09-06-2010, 10:15 PM   #296
JML55
JML55's Avatar
Tri5
Here is a picture of what i used. Heat shield of a truck exhaust stack.
Old 09-06-2010, 10:34 PM   #297
JML55
JML55's Avatar
You're the winner.
Yes I got a pair of 57 GMC bullet because i like that they have a little bit more character then the 55 ones with the cone part in the center. It wasn't just a swap they had to be modified to fit right. I guest since the 57 doesn't have the crossover bar they have a little bit different shape, they are shorter and do not mount quite in the same location. First i had to cut out the inner braces and remount them to fit the holes in the bumper. Then i added a strip about 1 1/2" that i cut of some old beat up 55 bullets i had to the edge to give me a place to attach the crossover bar.
Old 09-06-2010, 10:38 PM   #298
JML55
JML55's Avatar
Couple more pics.
Old 09-07-2010, 02:38 AM   #299
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Great work, it looks awesome!
ChuckDriver is offline   Reply With Quote
Old 09-07-2010, 07:13 PM   #300
Coronas56
Coronas56's Avatar
You're the winner.
Yeah! weeeeeeeeeeeeeee ,what did I win?
Semper Fi!
