Old 09-07-2010, 01:43 AM   #1
LS1_C10
Dont want a large Farva
LS1_C10's Avatar
How to measure wheel studs?
Im sure at least one out of five people come across this problem, but Google isnt helping. I need new studs on the front axle. They gotta be longer. I can get one off the truck with no problem, but the parts places can only look up by make/model/year and Jegs/Summit sells by exact measurements. What do I do when I have the stud in my hand to know what to buy?
I called Summit and they have longer studs. I just dont know which ones I need. "Wheel Studs, Press-In, 1/2-20 in. x 3 in. Long, .615 in. Diameter Knurl, Set of 5" doesnt really mean much to me.
My 74 K1500(broken and sold)
LS1_C10 is offline   Reply With Quote
Old 09-07-2010, 03:42 AM   #2
OARNGESI
OARNGESI's Avatar
Re: How to measure wheel studs?
Id take one of the studs to the store and find a lug that will fit it
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 09-07-2010, 03:45 AM   #3
LS1_C10
LS1_C10's Avatar
Id rather not eyeball measure something that has that many digits after the decimal. Its inviting problems.
Plus I need longer studs by at least 1/2". No one local has them. They HAVE to be ordered Summit or Jegs, which requires precise measurments.
Old 09-07-2010, 07:20 AM   #4
cdowns
cdowns's Avatar
i use a caliper to measure with// harbor frieght has them with electrronic display for readout, avery handy tool to have at quite reasonable prices
Old 09-07-2010, 07:37 AM   #5
Rollie396
someday it will be done!
Rollie396's Avatar
Yup I'd take my calipers,one of the old studs and one of the old lug nuts.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 09-07-2010, 10:44 AM   #6
dropd80s
dropd80s's Avatar
Just have the parts store look up the origional stud for your truck and look at the specs for it. Then get one how ever much longer you need.
O'Reilly's web site lists the specs. This is for a 74 K10 with a 350:
http://www.oreillyauto.com/site/c/de...2990&ppt=C0337
Just select your truck search for wheel stud. And BTW a decent parts store should be able to do this for you, but I know those are becoming few and far between.
dropd80s is offline   Reply With Quote
Old 09-07-2010, 11:29 AM   #7
LS1_C10
LS1_C10's Avatar
I tried that too. Unfortunately, the studs from the parts store dont have any info on them, just the application. So I would still need to measure, lol.
Old 09-07-2010, 11:40 AM   #8
LS1_C10
LS1_C10's Avatar
Harbor freight does have some decent caliper prices.
Old 09-07-2010, 03:34 PM   #9
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
take the part number from the oriellys... dorman for example and type in yahoo... dorman wheel stud catalog. boom. done. get the measurements from that wheel stud and get one thats longer. simple
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-07-2010, 09:39 PM   #10
dropd80s
dropd80s's Avatar
You dont even have to do that. The specs are online.
From the link above:
Dorman - Wheel Studs
Part Number: 610-179.1
Line: DOR - Limited Availability
•AutoGrade
•UPC: 19495101796
Warranty Info
Mfg. Defect Warranty
Detailed Description
Type: Serrated Stud
Thread Size: 7/16-20
Thread Pitch: Right
Knurl Diameter: .565 in
Length: 1-3/4 in
Shoulder Length: 7/8 in
Head Code: 179
Features: Zinc plated for corrosion resistance
Just search for your application. Find out what you have then you can get them from Summit ect. if you cant get them in the store. Bout as easy as it gets.
Old 09-07-2010, 11:52 PM   #11
LS1_C10
LS1_C10's Avatar
•AutoGrade
•UPC: 19495101796
Warranty Info
Type: Serrated Stud
Thread Pitch: Right
Length: 1-3/4 in
Head Code: 179
You are right. That was extremely easy. Muchas Gracias!
http://www.summitracing.com/parts/MOR-46220/
Wheel Studs, Press-In, 1/2-20 in. x 3 in. Long, .563 in. Diameter Knurl, Set of 5
These are VERY close to those specs you gave me. Are they close enough?
Old 09-08-2010, 07:52 AM   #12
way2lo2
way2lo2
way2lo2's Avatar
I may be confused here but are you trying to put half inch studs where a 7/16" stud was originally?
way2lo2 is offline   Reply With Quote
Old 09-08-2010, 12:42 PM   #13
LS1_C10
LS1_C10's Avatar
I thought that number referred to the twist for the lug nuts. Am I completely wrong? cus when I search 1/2 20 on summit, I get lug nut results.
Old 09-08-2010, 01:34 PM   #14
smbrouss70
smbrouss70's Avatar
The numbers that you are referring to is the stud diameter and the thread pitch in teeth per inch. If you originally had a 7/16"-20 RH thread wheel stud, then you should go back with a 7/16"-20 RH thread wheel stud. This should be more of what you are looking for...
Wheel Studs
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-08-2010, 02:02 PM   #15
LS1_C10
LS1_C10's Avatar
I saw those too but I was under the assumption that the shoulder was longer on mine.
Old 09-08-2010, 02:49 PM   #16
smbrouss70
smbrouss70's Avatar
You're right, the front studs on your truck should have a longer shoulder. The only option I see without going to a smaller knurl diameter is this one. The knurl is slightly larger and you may have to drill out the hubs a hair, but more than likely they'll press in with just a little more force.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-08-2010, 03:03 PM   #17
LS1_C10
LS1_C10's Avatar
Those seem to be exact except for the knurl. Will it be close enough to work?
Old 09-08-2010, 03:12 PM   #18
smbrouss70
smbrouss70's Avatar
There is a difference of 15 thousandths of an inch between the two, with the new one being the larger one. I would think that they would press-in fine, with just a little more resistance than a stock replacement stud.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-08-2010, 03:35 PM   #19
LS1_C10
LS1_C10's Avatar
Sounds like a job for WD40! lol. Ok. you made up my mind!
Old 09-15-2010, 04:26 PM   #20
Shon
Did you ever purchase and install longer studs? I want longer ones too and hard to find the right ones, as you have noted....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-15-2010, 04:31 PM   #21
LS1_C10
LS1_C10's Avatar
Ever have one of those months where you gotta sell the wheels n tires on the truck to afford to install the new ones? Lol. They are sitting in my Cart on summitracing.com.
The guy who posted the Dorman info ultimately saved my butt. Goto https://www.dormanproducts.com/catal...ec10_Part2.pdf and find your application, then goto summit and type in the knurl and the turn. Like 7/16 20 .565 or whatever it is
Old 09-15-2010, 04:33 PM   #22
Shon
Heard that!
Old 06-10-2016, 12:34 PM   #23
Heydon
Heydon's Avatar
Hi
Bringing the thread back from the dead.
I have a 1965 C10 but it has more modern hubs/ discs. How do I identify these to be able to identify the stud? I know that it is 5x5, the studs are 1/2 inch diameter.
Or should I just remove a stud and identify it by measuring it? Being in the UK it is hard to just pop to a shop with a stud and find someone capable of identifying it / supplying a replacement, so I will need to order online.
Lifetime Cal look VW fan on a new Chevy truck shaped adventure....
1965 C10 SWB Fleetside, LT1
1967 VW Bug 2332cc
Heydon is offline   Reply With Quote
