Old 09-07-2010, 09:08 PM   #1
butler57
butler57's Avatar
new guy with a question
I'm very new to the site and thought I should introduce myself. I picked up a '72 earlier this summer and found this site to be an excellent source of info. One of the first things I did on the truck was pull out the dash cluster and fix the gauges and lights as the only thing working was the speedo. I tracked down everything posted on how to tell if the gauge was working and ended up only needing to replace the float on the sending unit. Anyway, I really appreciate all of the knowledge that is shared here. Sure helps out.
here's a picture of the top of the gas tank. Any idea why the PO would block one line?
butler57 is offline   Reply With Quote
Old 09-07-2010, 09:11 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: new guy with a question
Unless the vent lines that run up the cab are broken, I really dont understand why either.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-07-2010, 09:44 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
A lot of people remove the charcoal canister and block off that connection on the tank. Then install a vented gas cap.
I left the hose on my tank to act as a vent for the tank on my '71 since the gas cap on it is of the non-vented type.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-08-2010, 12:02 AM   #4
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I don't know about your question but WELCOME to the forum.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 09-08-2010, 09:45 PM   #5
butler57
butler57's Avatar
Hey shyguy, what do you mean by a charcoal filter? I disconnected the other line, unbolted the vent piece but it's just a looped fuel line. where is the filter?
Old 09-08-2010, 09:57 PM   #6
Shyguy
Junior Member
Shyguy's Avatar
The charcoal cansiter filter thing is inside the passenger fender at the very front by the battery.
I imagine there are people with these trucks that don't even know they are there.
I think they are '71 and newer trucks that have them and I have found not all of them have them.
Old 09-08-2010, 11:35 PM   #7
Seraph
Seraph's Avatar
is it necessary to run a charcoal canister if your truck came with one or can u just bypass it.
1972 chevy c 10 longbed
2000 Ford Powerstroke (daily driver)
Seraph is offline   Reply With Quote
Old 09-09-2010, 12:00 AM   #8
Seraph
Seraph's Avatar
never mind the answer i was looking for was in a previous post......i must be really tired...
Old 09-09-2010, 02:08 AM   #9
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: new guy with a question
The line that is plugged is the cab line that runs up into the top passenger side of the cab. I would think the only reason to do what he did was he was getting fumes out of it when the tank was full and getting hot. Most fumes are from the gas tank cap itself though not those lines.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
