Old 06-06-2003, 07:08 PM   #1
BigBlack68
Negative Camber
BigBlack68's Avatar
Stereo System
Can some people please post some PICS of there stereos,i need some ideas on where to put my subs and other speakers,thanks alot
BigBlack68 is offline   Reply With Quote
Old 06-06-2003, 08:25 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Can not post pic's right now!!!! Sorry
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-06-2003, 08:31 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
Well, there are lots of places to put speakers. Do you still have the in-cab gas tank? How do you feel about cutting the doors? Are you going for sound quality or just plain loudness? What kind of music do you listen to? What is your budget? Answering these questions will help us send you in the right direction....
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 06-06-2003, 09:14 PM   #4
BigBlack68
Negative Camber
BigBlack68's Avatar
Yes i still have in cab gas tank,dont care about cutting doors,i want something that sounds good yet is still loud,right now i have two 15 audiobahn subs 2 sets of 6 1/2" pioneers and a kenwood cd player,i want to put all of this in some time soon and need some ideas,thanks for help on this
Old 06-06-2003, 09:16 PM   #5
FILICE72C10
FILICE72C10's Avatar
check these out
http://67-72chevytrucks.com/vboard/s...threadid=52040
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
FILICE72C10 is offline   Reply With Quote
Old 06-06-2003, 09:18 PM   #6
FILICE72C10
sub location if you have a tank in the cab. My idea
http://67-72chevytrucks.com/vboard/s...threadid=51433
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
Old 06-06-2003, 09:21 PM   #7
FILICE72C10
last one
http://67-72chevytrucks.com/vboard/s...threadid=52495
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
Old 06-06-2003, 09:57 PM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
BigBlack68, if you've still got your gas tank, you can forget about installing those 15's. Even w/out the in-cab gas tank, you would be hurting for leg room/enclosure size w/2-15's. I've seen it done, but it would be over-kill for your 61/2's. Since you have 15's, I guess you like bass. So why not sell the 15's, buy two 10's and a very powerful, quality amplifier. Put the 10's under the seat in a proper enclosure. With enough clean power, they will rock.
You can then put the Pioneers in the doors or kickpanels. There are some kickpanels you can buy w/cheap 61/2's already in them. Better yet, get your local car stereo shop to build some custom kick panel pods angled toward your listening position. You might even consider some 61/2" component speakers if you have the cash. You'll be glad you spent the $$$!!
I may be overcomplicating things for you, if I am, let me know and I'll try to explain things better....
Old 06-06-2003, 11:13 PM   #9
Mike C
Mike C's Avatar
Kicker separates in the door panels, crossovers on kickpanels. Free-air 10 in open back box, Crossfire 100x4 amp, and not pictured, 6 disc changer under drivers side.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-07-2003, 02:56 PM   #10
cruzn72
I can't find the pics of my stereo right now but I will post when and if I find them. I ran two Cerwin Vega 10s behind the seat. They take alot of air space, but deliver alot of bass. I ran a CV 6.5" mid and a Pioneer tweeter in the lower kick panels. I mounted the amps and crossover under the seat.
http://photos.yahoo.com/cruzn72@pacbell.net
cruzn72 is offline   Reply With Quote
Old 06-07-2003, 03:57 PM   #11
BigBlack68
Negative Camber
BigBlack68's Avatar
thanks for all the pics and info,i guess ill just take the 15's and put them in my 64 caddy,and put some 10's in the truck,I have a set of Rockford fosgate 10's around here some where,thanks again
Old 06-07-2003, 09:40 PM   #12
19mike69
you guys that cut the dash for a cd player,was it hard to get one mounted in there?....is it all flopping around or is it pretty sturdy?
19mike69 is offline   Reply With Quote
Old 06-07-2003, 09:46 PM   #13
Riveted1
Tasty Cakes!
Riveted1's Avatar
Mine is just as sturdy as mounting it in any other car.....
Old 06-08-2003, 12:38 AM   #14
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
just cut it exact..
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 06-08-2003, 12:08 PM   #15
19mike69
what did you cut it with?
Old 06-08-2003, 09:42 PM   #16
cruzn72
When I has my CD player in the dash I usde the mounting tray and some plumbers tape for the back as a hanger. My truck is lowered and at the time it had leafs which made it ride like a tank. I purposely tried to skip the CD and could not.
Old 06-09-2003, 07:22 AM   #17
Riveted1
Tasty Cakes!
Riveted1's Avatar
Just use a sawzall. You can rent them for cheap....
Old 06-09-2003, 08:31 AM   #18
Mike C
Mike C's Avatar
Sawzall is a bit overkill... I taped up my dash with masking tape, then marked the opening on the tape and cut using a jigsaw. Much easier to control the jigsaw than a sawzall. The tape keeps from scratching the paint or chipping the edges. Works well. Be darn sure you don't cut the hole too big. I cut mine slightly small and opened it up with a file. I suspended the back of the head unit with the strap that comes with the new stereo (You know, the one everyone throws away!) and the stock lug.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-09-2003, 01:11 PM   #19
Ackattack
Ackattack's Avatar
I made a center console to house a 10" sub along with the amp. It also has a little area for junk. I obviously have bucket seats too. The way this console is designed thouh, I can still have a 3rd passenger (though they're not real cumfy)
I'm now in the process of building a new center console that will also house the sub and amp, but it will be a little more "show" and will enclose the floor shifter, peopl won't be able to sit on it, and it won't have a junk holder.
Ackattack is offline   Reply With Quote
Old 06-09-2003, 05:34 PM   #20
Riveted1
Tasty Cakes!
Riveted1's Avatar
Mike C., I was joking about the sawzall. Sorry I didn't make my sarcasm apparent enough! Yeah, go w/the jigsaw!
