Need help with removing front fenders
![]() Thanks!!!!!!!!!!!!!!!!!!!!!!! |
Still Learning
Re: Need help with removing front fenders
Namky,
It isn't too hard at all if you have the right tools. I would recommend a little wD-40 too if you have it. You will need a 1/2" and 9/16" shallow socket and some extension(s). Bring a long 1/2" wrench and a good pair of vise grips. I also like to use a universal 1/2" for the upper ones behind the grill. There are a couple of bolts on the bottom you will need the 9/16" socket for. Plan on at least 15-30 min. to pull it depending on how rusted the hardware is. You will want to coat the ones in the front with the wd-40 before you ever start. If you pull the side marker lights you can access the back side of them, the rectangle nuts are spot welded/crimped in and if they are rusted too bad it will just break loose and spin. You will need either the wrench or the vise grips to hold the retangle nut if it breaks. (ask me how I know about this) ![]() This might help Forgot to add there are about 12-15 bolts total.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 09-08-2010 at 08:26 PM. |
Thanks heading to salvage yard now!!!
