Old 09-07-2010, 11:56 PM   #1
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
tonneau covers
so for some time now. I have been looking for a good looking tonneau cover. I want one that is pretty low pro, I have seen some pics of them on here but never any that show how high of the bed they sit, Anyway, i saw this in my summit mag today and I was just wondering if anyone has used or seen them?
http://www.summitracing.com/parts/SUM-484530/
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 09-08-2010, 12:32 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: tonneau covers
I say build your own! Here s my tonneau cover in progress...
I spent $90 at Home Depot but that doesn't include the material to cover it.
Old 09-08-2010, 12:40 AM   #3
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: tonneau covers
I know that ETsC10 has one. At least one like it. I will see if I can direct her here to say a thing or two.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 09-08-2010, 12:55 AM   #4
54Caddy
GM Addicted
54Caddy's Avatar
Re: tonneau covers
a Corts60 more info on your cover..
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-08-2010, 01:41 AM   #5
Corts60
Just here to tinker
Corts60's Avatar
Re: tonneau covers
All I did was buy two 4x8 sheets of 3/8" underlayment particle board, one roll of 100 sq. ft. underlayment (2in1) padding, and about 9 firring strips or 1x2's. I will get some more pictures tomorrow of the framework.
As far as what is holding the cover up, I used 1" x 48" aluminum angle that is 1/16th thick. I riveted that to the backside of the upper bed rail which leaves about 3/4 inch of the aluminum to catch the cover.
I'm sure that all sounds confusing but I will take some better pics tomorrow to help describe.
Old 09-08-2010, 01:44 AM   #6
54Caddy
GM Addicted
54Caddy's Avatar
Re: tonneau covers
Sounds perfect with pictures please. I have had the same ideas for the rails are going to mount actuators on anything so it will lift up??
..Mac’s Garage..
IG:MacsGarage
Old 09-08-2010, 01:34 PM   #7
nbpro
Re: tonneau covers
We mounted angle iron along the bed rails, the two sides and the back of the bed. Built a frame out of pressure treated 1x2's. Went to a local sign shop and got some aluminite(two pieces of aluminum sandwitching corregated plastic, very light) scraps, in other words signs they had discontinued or was no longer able to use. Come in 4x8 sheets 3/8's inch thick. $20 for two sheets. Screwed it down to the frame, added a sheet of plywood underneath for strength and mounted it on the bed. Check my build thread for final results.
Plan on covering it with tonneau cover material bought online.
nbpro is offline   Reply With Quote
Old 09-08-2010, 08:40 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: tonneau covers
go any more infor on what your useing and how is it held in
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-08-2010, 09:10 PM   #9
nbpro
Re: tonneau covers
We used what's called a desk lock at each corner. Just haven't gotten all the pics up yet. Worked out pretty well. Can lock it and keeps it from flying open. I am unsure of this underlayment particle board. My brother that has been a carpenter for 30+ years is unsure as well. Anxious to see how this holds up. Another thing you could use is FRP board, which is the board they use in resteraunt walls.
Old 09-08-2010, 10:09 PM   #10
Corts60
Just here to tinker
Corts60's Avatar
Re: tonneau covers
Here are some more pics of the cover after we put the vinyl on. As far as how it sits, I tried to get a better pic but I literally just took the angle iron and tucked it up underneath the lip of the bed rail and riveted it in. As of now, that is the only thing holding up the cover. That and some c-clamp pliers...I haven't decided on how I am going to fasten it just yet.
nbpro-
I am not a carpenter and I am also unsure of how this will hold up. If I were to do it again I would not use the particle board. I thought it would make it lighter, which is what my goal was. I'm not too sure it's any lighter than if I would've just used plywood.
Old 09-08-2010, 10:18 PM   #11
nbpro
Re: tonneau covers
The way you have it wrapped up, it looks like it may be fine. I just know they stopped from using it under vinyl because of the moisture issue. FRP board, which you can buy at Lowe's, is a good thing to use. Lightweight and pretty durable. It was just cheaper for me to use the alumilite. Where did you get your material?
Old 09-08-2010, 11:27 PM   #12
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
Re: tonneau covers
Wow man, that looks pretty sweet bro.
Old 09-08-2010, 11:35 PM   #13
benoit454
Chris
benoit454's Avatar
Re: tonneau covers
we made one for an s-10 once, 2 sheets of 5/8 osb plywood, a 6 foot 1x12 a bundle of furring strips 1x3's, gallon of liquid nails construction adhesive, staple gun, a tonneau cover we had that was velcro type or you can buy the outdoor vinyl online.
We did sorta like the above, used sheet rock screws to screw the 1x3's to the lip inside the bedrails, they sit about 5/8 little more below the top of the bed rails, cut the plywood to fit inside the rails, stepped in the thickness of the 1x3 like 3/4 inch, and built a frame of 1x3's laying flat, screwed those to the plywood, used the 1x12 to join the 2 pieces of playwood together, not long ways either, across the bed, one four foot by however wide the bed was between the rails the other same distance between rails but as wide as needed to fill the gap from the front of the bed to the other piece of plywood. Then we smeared the glue all over the top, laid the tonneau on it, working out the wrinkles, folded it under and stapled the bottom all around. We laid it on the truck and used a screw in each corner to hold it down, but did consider using lift supports and hinges to let it raise, truck got totalled shortly after building it though.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 09-08-2010, 11:47 PM   #14
Corts60
Just here to tinker
Corts60's Avatar
Re: tonneau covers
Old 09-09-2010, 12:10 AM   #15
nbpro
Re: tonneau covers
OSB. be careful when buying this stuff. Been major recalls on it. Believe it or not, was not shipped in from China. AC plywood would be better, a little more expensive. We plan on using the hydraulic cylinders off of the back door of our mom's van, which weighs probably 150 lbs, so I'm certain it'll hold it up. Van was wrecked shortly after she passed away. Just preserving memories.
Old 09-10-2010, 10:37 AM   #16
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: tonneau covers
Neat projects guys! I love the looks of a nicely fitted hard tonneau.
Joe, as Matt mentioned, my tonneau is nearly identical to the Summit
tonneau you linked. Mine is an Extang Black Max and they are very nice
considering the attractive price. Very well made. The upper-most bow
crown I would estimate to be about an inch and a half off the bed rail.
Advantages are that there is no damage to your truck, durability and
versatility when hauling taller loads.
Disadvantage...snaping the last few snaps can be a real challenge.
I'll plop a photo on here later today.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 02-18-2011, 07:57 AM   #17
70c10
67-72 Addict!
70c10's Avatar
Re: tonneau covers
Corts60- Nice job! I've been thinking of making one to cover my home made carpeted bedliner.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-18-2011, 03:56 PM   #18
blazer2007
Re: tonneau covers
here are some other pics I found online,going to try one myself
blazer2007 is offline   Reply With Quote
