09-09-2010, 12:12 PM | #1 |
86 Rear End D60?
Ok, I found this rear end under an 82 or 86 pickup, one ton I believe. It's 8 lug, heavy duty springs, huge drums and it's a Posi. It said 60F on the lower pass corner of the pumpkin I believe.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
09-09-2010, 04:21 PM | #2 |
Re: 86 Rear End D60?
Ok, looked at it closer. Might be a 14BFF based on the cover. Not sure.
Also, is that factory rear swaybay worth anything? Thinking about grabbing the whole setup for my blazer if it will be better than what I have (12bolt, 6 lug, open)
09-09-2010, 05:48 PM | #3 |
is a fungineer
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
09-09-2010, 06:53 PM | #4 |
grab both bars
09-11-2010, 12:23 PM | #5 |
The rear is worth about $100, maybe closer to $150 if it has good gears (like 4.56).
I'm not sure, but the rear swaybar setup might be worth as much as the rear. Not many trucks had it, and the ones that did probably don't anymore (like my '79 camper special). It probably can only be used on a 1ton though because of the perch spacing. That truck also has the equipment for a slide-in camper.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban Last edited by USSkoval; 09-11-2010 at 12:24 PM. |
