09-10-2010, 06:49 AM | #1 |
Which rearend fits a 46
A body of mine picked up a nice 46 project. He is wanting to swap out the original diff for something a little better. Does anyone have a good donor list and the width. I think a gbody montecarlo should be close, but thought I would ask somebody that has already done it.
Thanks Posted via Mobile Device |
09-10-2010, 02:56 PM | #2 |
Re: Which rearend fits a 46
If you still have the stock rear, measure it over the drums and you should get something around 60". This means a G-body will be somewhat too narrow, but it should work ok if you are wanting the deep wheel look. For a closer match to stock, look at 68-74 Nova, 1st gen Camaro, or 4WD S-10. Early Chevelle will work too, if you don't mind dealing with the suspension brackets and lugs. I have used 55-57 passenger car rears in these trucks, but those are getting rather scarce/pricey now.
On a related issue, the stock front track is about 2-1/2" narrower than the rear, so keep this in mind if you are going to an IFS and you want the F&R track to match. Ray |
09-11-2010, 12:52 PM | #3 |
Thanks raycow,
I read somewhere that the 46 and down was narrower than the AD trucks. I have a 53 and it was suppose to be 58-60. The older was said to be 56-58, but I like to here a couple different opinions. |
09-11-2010, 04:44 PM | #4 |
Your figures are probably in the ballpark for track. The AD rear is about 62" over the drums. Track is less because of the offset built into the stock wheels.
I installed a 52 passenger car powerglide rear in a 46 truck and it was almost identical to stock width. That's where I got the 60" drum to drum dimension. Ray |
09-11-2010, 08:32 PM | #5 |
You are right. My buddy measured the stock rearend today. Drum-drum 60.5 . I went with a 8.8 out of a ford explored for my 53
09-12-2010, 10:45 AM | #6 |
Would you happen to know the width of the explorer rear? I'm not much good on Ford parts.
Ray |
09-12-2010, 12:33 PM | #7 |
I'm going out to work on the truck here in a few. I ll measure it and post it up.
09-12-2010, 08:23 PM | #8 |
95 or 96 explorer with disk brakes 31 spline 8.8 measures 59.5
09-13-2010, 04:31 AM | #9 |
Thank you for checking. That info could come in useful.
Ray |
09-13-2010, 02:45 PM | #10 |
My '41 has a 1982 S-10 rearend, fits well, now I have 5 lugs on back and 6 on the front. That will change when I put a disc brake kit on the front with a 5 lug pattern.
" I never think of the future. It comes soon enough " - Albert Einstein |
09-13-2010, 04:59 PM | #11 |
Ok. Thanks
09-13-2010, 10:14 PM | #12 |
A 7.5 out of a 82-92 Camaro/Firebird is 60.5 inches.
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
09-15-2010, 09:21 PM | #13 |
when I had my 46 I put a rear end in out of a 76 ish suburban. the axle pads where in the right spot anddidn't require anything. I rolled out the original one and rolled in the new one. Mine was also a 12 bolt truck posi with 373's.
Harley |
