Old 09-12-2010, 02:34 PM   #1
remist17
remist17's Avatar
Converting V6 to V8 engine mount question
I am swapping out a V6 for a V8 in my 1987 R10. I knew the mounts are different so I went to a you pull it and found a 86 that had the 8 cyl brackets. It had a utilty body so I am assuming it was at least a 3/4 ton truck. Came home and the brackets are not even close to matching up to the holes in the frame.
My questions:
1- Is there a difference between 1/2 ton and 3/4 ton engine brakets?
2- Is there mounting holes in the frame for a 8 cyl or do I have to drill
3- Is there a difference between 4x4 and 2x4 brakets?
(the brakets in question are the ones that mount to the frame and cross member)
What am I doing wrong !
Please help!!!
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 09-13-2010, 08:03 AM   #2
remist17
remist17's Avatar
Re: Converting V6 to V8 engine mount question
bump for some help
Support the Troops.
Old 09-13-2010, 08:58 AM   #3
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
im pretty sure that there are diffrence bettwen 4WD and 2WD motor mounts
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 09-13-2010, 12:05 PM   #4
remist17
remist17's Avatar
ok... I could have swore the one I pulled was a 2 wheel drive.... but maybe i was wrong... I will look tomorrow (go back to the yard)
Support the Troops.
Old 09-13-2010, 02:25 PM   #5
remist17
remist17's Avatar
Since I have not gotten much support I sat down at the junk yard and compaired several square bodies. My 87 had a 1 3/8 top flange of the frame and a 2 1/2 bottom flange of the the frame. The engine mounts center line to centerline was 17 1/2"
Looked at a 86 C10 Truck Top flange of frame was 1 1/4" bottom of flange was 2 1/4" and centerline to centerline was 16"
Looked at a 87 Suburban Top flange of frame was 1 3/8" bottom of flange was 2 1/2" and centerline to centerline was 17"
So to answer many people no these frames are not all the same.
Hopefully if anyone searches they will find this thread and shed some light.
Support the Troops.
