#101 |
Re: SGTUSMC '59 build
ERRR...I'm a bozo! After flipping the perch I noticed my pinion angle was WAY off. I had to flip them back and weld up the holes. So now I'm back to head hunting ants on the black top.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
#102 |
Couldn't you wedge the perch between the spring and housing? Done on lifted 4wd trucks...
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 09-13-2010 at 12:53 AM. |
#103 |
yeah just get get a pinion angle corrector. they are made for dropping or lifting applications. They are like a drop block but a wedge. I's sure you have seen them..
1950 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=335667 1965 F*rd Stang http://67-72chevytrucks.com/vboard/s...d.php?t=399891 1931 F*rd Model A http://67-72chevytrucks.com/vboard/s...d.php?t=496016 1954 Chevrolet Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=486183 |
#104 |
I have a couple wedges that came with lowering/lift kits that I didn't use and a few angled drop/lift blocks. On the rear I used a flip kit. I just don't like the idea of adding a wedge or block to it. I'm sure it's safe but I had a block shatter on me in the 90's in a Nissan truck. When I pull the rear-end for paint I'll yank out a leaf or two. They also make drop hangers for the rear perches that I could use to get lower. Since my wife will be doing most of the driving I want her to still be able to drive it home if there's a bag failure. I must be getting old if I didn't notice the pinion angle facing the sun. I'm just glad I caught it and not someone else.
#105 |
I ran 4" Rancho lift blocks on my rear with couple of degrees angle built into them from 1985 to 1998 without any problems. Drove it daily and on some pretty knarly off-road stuff, fording streams, etc. Mine are solid cast steel with pin and hole for locate on the spring and housing. Speedo didn't work but I estimate it was about 50 K miles because I went thru 1.5 sets of tires.
#106 |
Mocked up the front end today. I'm surprised how it all fell together. There's only one bolt per fender holding it all together. I will have to fab up a rad mount and cut the sheet metal for access to the rad filler (going to use the 88 rad). Doesn't look like I'll have to cut the frame horns. I'll have to join the 88's bumper brackets to fit the 59 bumper. It looks to easy...I think I just jinxed myself!
#107 |
Looking good.
Kim |
#108 |
Coming right along.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#109 |
I've been giving the wife some welding lessons for about a week now. I tacked the old tailgate to the bed. To keep it somewhat square while mocking up mounts and such. I ordered a new tailgate & hinges. I spent the good part of a day removing the broken tailgate hinge bolts and welding in new cage nuts.
I left the wife out in the garage for a while. When I came out, she said she finish welding the tailgate up for me. She welded both sides, also laid a fat bead on the inside. It took all I had to keep from cry'n. Here's her handy work. Not to bad I guess...hahaha ![]() ![]()
#110 |
She did a good job! ROFLMAO
But really, a little careful grinding and you'll be good as new.... The best part is at least she's interested in it! Mine doesn't like to go in the garage when I'm welding and grinding because "it smells awful" , sigh
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
#111 |
I guess I bought a new tailgate to mount to my garage wall. Were just gonna have to go tailgate-less now. As much as I wanted to scream and yell...those days are over. (lucky her!)
#112 |
Now its time to teach her how to grind a weld off.
![]() ![]() Last edited by Panelman55; 10-07-2010 at 07:58 PM. |
#113 |
I honestly like the tailgates welded up. I built a custom bed for mine and eliminated it.
Kim |
#114 | |
I did some sanding & grinding between the bed and gate that needs attention (paint). I have no clue how to get paint in there now. I did mention to her that the new front bedside will not see any welds. I have to remember not to tack the doors. Last thing I want is to "Dukes of Hazzard" my way in every time.
#115 |
Hey Sarge, It's been some time since I was on your build thread and I got to say your truck is really coming along nicely! I like the flip hangers and your wife's welding! Keep up the good work man, I can see it's paying off so far.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#116 |
By the way, cool pics. I sure wouldn't want to be a 18-20 yr old on the receiving end of that....
#117 |
Added a floor today.
#118 |
Registered Chevy Owner
I'd swear that you're a pro builder with the thing that you're doing on this build.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#119 |
Naw Nick, not even close my man!
#120 |
What is the donor for the bed floor? I've always wondered if a later model metal bed floor would work. You are making great progress.
#121 |
It's the bed from the donor truck (88 Silverado long bed). The inner width is almost perfect. The bed has floor cross braces welded in. If my frame rails weren't so high I could have used the whole thing. On a stock 59 bed I'm sure it would fit nice. Let me know Patrick if you'd like some measurements and pic of the 88 bed.
#122 |
A 58 parts tgruck that BobinBC and I parted out had a welded in box floor out of a later model. Looked pretty good. To the uneducated it would look stock. Not a bad idea if you are allergic to wood.
If the women don't find you handsome, they should at least find you handy... Red Green Keep your stick on the ice, Woodbutcher |
#123 |
I finally got my white walls buffed and mounted to my rims. Tires are BFG 155/80/15 on 15x5 rim and BFG 205/60/15 on 15x7. Hope to get them mounted sometime tomorrow. They came out pretty nice. Now I need to find some beauty rings and some sort of caps.
#124 |
I'm thinking about getting some of these for my truck, and I'm sure they would look just as good on that one
#125 |
Moderator
![]() Join Date: Jul 2006
pass on the spider caps, they are overpriced and fit like crap. bullet lugs and shannon cones look about the same and are easy as pie.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
