1987 gmc with code 42
okay i dont know what happened but basically i replaced my spark plugs, spark wires, and cap and rotor on my truck last week and within the same day of driving it around it started to die on me when coming to a stop at a stop light or at lower speeds in general. then it gave me a code 42 for the EST.
well i checked all my wires and everything was hooked up fine and the timing was set correctly. I have a spare ignition module so i went to oreillys and tested it first to make sure it was still good and he cycled it 3 or 4 times so it would get hot and it still passed. okay then i swapped it out with the one on my truck and went and tested that one as well and it tested ok also, so both modules were good. the truck still had the same issue, dying on me randomly and setting the code. i had to drive to beaumont the other day and i had no choice but to drive it and hope it doesnt die. during the drive it died once, then i got it restarted and kept driving it, several miles later it tried to die again so i throttled it and that kept it running but with the check engine light ON the whole rest of the way to beaumont. while in beaumont i pulled the whole distributor out and replaced it with another one under warranty ![]() so... i have a completely new ignition system except for the ignition coil, the wiring that goes between all the components, and the ECM itself. I'm thinking the wiring pigtails and such are just too old and i should splice all new ones in. any thoughts? |
Addicted to Rust
![]() Join Date: Dec 2009
Re: 1987 gmc with code 42
Is it sputtering out like fuel, or cutting off like using the switch? I had a TBI truck that had marginal fuel pressure and it was unpredictable. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#3 | |
could the ecm be failing? and if that was the case wouldnt it have a code for itself being bad? i still havent checked the coil either though. its 4 years old. an accel unit. oh and i did check the fuel pressure two weeks ago and adjusted it to 15 psi. i cant watch it though because i dont have a gauge set up for that. i need to get one. know of a decent kit? Last edited by jesdude7789; 09-14-2010 at 12:40 AM. |
Addicted to Rust
Try to find a GM service manual, there should be a trouble tree for the est. The est module is square and has a flat plug, I do not remember how many wires in it, grab one from the pick and pull and swap it. They didn't really go bad that often. Jay
#5 | |
![]() Quote:
Thanks! Posted via Mobile Device Last edited by jesdude7789; 09-14-2010 at 09:21 PM. |
ebay will be your best bet.
Jay 2001 Pontiac Aztek GT |
Make sure that the connectors are not coming loose on the coil. Mine did something similar and I called my mechanic while on the side of the road and he told me to check the connecters that connects to the top of the coil, one of the what i call snaps had broken so it would work its way up just enough to kill the truck, i mashed it back down and it restarted and I mde it home and went to the bone yard to get a good and replaced the broken one.
