Does 85 GMC 305 have O2 sensor ?
I have searched , but have found conflicting answers.
A friend has a 85 GMC that's running super rich all of a sudden. It has the electronic quadrajet , but does this mean it will have an O2 sensor? I'm his mechanic by default since I sold him the ride ![]() Also what does the ported vacuum swith on top of the thermo housing control ? Any help is appriciated. Zac
Working on my first 1,000 post. I'm sure I'll get there before this project is over ![]() |
All About the BOWTIE
Re: Does 85 GMC 305 have O2 sensor ?
As far as the O2 sensor goes... is this truck set-up for emmisions.. i.e smog pump.. tubes.. Check Engine light?... If you want to hunt the sensor down,.. look on the exhaust pipes just under the manifold.. thats where they usually are.. mine is anyway..
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
I have never herd of anything carburated using an o2 sensor. The fuel should be controlled by the metering rods. The thermal vacuum switch to my knowledge will block vacuum until the engine is warm, on my engine it looks like it blocks vacuum to the choke pull off on the carb and keeps the secondaries from opening.
![]() Join Date: Dec 2008
Pretty sure the 85’s were CCC <computer control command> which do in fact have a really simple computer, electronic idle mixture, o2 sensor, etc Check your exhaust work for an 02 sensor. If you find one, you have CCC. http://www.rockauto.com/catalog/x,ca...28H%2529%2BOHV
BAD BOW-Silverado XST
Yes, some California models had them. My factory 83 manual has wiring for an O2 sensor on some models.
i would say yes, it has an Oxygen sensor; HP's Rochester Carburetors is a good book to get in general.
If yer too cheap to buy it---which is totally understandable you could utilize googlebooks: Pls scroll down and refer specifically to pgs 58-59: http://books.google.com/books?id=DwU...page&q&f=false Also, here is another link that i think is good concerning CCC, oxygen sensor etc.: http://www.robertpowersmotorsports.com/CCC.html Last edited by C-10 simplex; 09-15-2010 at 09:52 AM. Reason: more info |
Awesome, i had no idea. What exactly does the computer control on the carb, is there a servo or something?
CCC systems generally have an O2, my 83 Malibu did. Typically in the right head pipe
Eric 1992 Oldsmobile Custom Cruiser 1986 Chevrolet C10|5.3L|TKO600|Shortbed|Custom Deluxe 1983 Malibu Wagon|TPI 305|T5 5 speed|3.73 non-posi Last edited by MalibuSSwagon; 09-15-2010 at 05:52 PM. |
Insert Witty Text Here
AFAIK, on trucks, it would only have an O2 sensor if it had California emissions. My '86 did not have one. The "computer" on mine is just a knock sensor and a distributor with ESC. Nothing more.
Slonaker |
California is really lame about the whole emmisions thing.. What Cali trucks were required to have,. completely restricts the power.. And you really can't do too much else, as far as high performance, that's beyond emmisions to better it,.. they have to remain the way they came from the factory in order to pass.(as far as pump, plumbing, working C.E.L, and so on) if the C.E.L. light doesn't work,.. out you go, and dont come back till it does.. or take out a small loan to have it diganosed and fixed...or if it's stuck on... same deal.. they won't touch it
What else is messed up is a lot of these "Smog" guys dont really know how to, or are willing to tinker with the q-jets to get em to pass.. they're so use to the electronically controlled.. set-ups that are easy to test and send em out... like a Jiffy-Lube. Last year, it took dude a whole day to test and adjust, and test again to get it to pass.. California Emmisions Laws SUCK!!!!
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 09-16-2010 at 01:43 PM. |
Badass
What year did they start this computer controlled carb? My 84 don't have this
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#12 | |
Could someone explain what the unit poking out of the top of the carb is? Its got a plug for a couple wires, it looks like a cylinoid. |
Just hit me, the o2 censor is just there to turn on the "check engine light".
#14 | |
With a rat's nest full of vacuum lines??... (zip-ties have become my new best friend..lol) BTW.. that automatic cold choke set-up is a pain in the butt!! to get right... either to high, or won't activate...
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 09-16-2010 at 02:45 PM. |
#15 | |
My choke is all screwed up too, I never drilled out the rivets to adjust it when i did my rebuild and apparently its not adjusted right. I finally had to remove the idle step up cam from the linkage so it would idle down. Last edited by irishman999; 09-16-2010 at 03:01 PM. |
#16 |
Cruzzzn' Vet
#17 | ||
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 09-16-2010 at 03:50 PM. |
#18 | |
That Carb does look brand new, does anyone know what the blue electronic plug unit on the top of it is? |
#19 |
Cruzzzn' Vet
The blue plug goes to the Mixture Control Solenoid, mounted in the float bowl it controls the air and fuel mixture in the Primary bores.
The carb is a 7yr old rebuild, just gave the truck a tune up and sprayed the carb down with Gumout. Last edited by Malo83; 09-16-2010 at 04:45 PM. |
#20 |
What controls the solenoid? Im getting erratic performance out of my carb and wondering if this solenoid is causing it.
#21 | |
People often assume it is a computer controlled quadrajet because it has a plug, but it is not. Apparently on CA emissions trucks, they are computer controlled and have a check engine light, computer controlled carb, and an O2 sensor. Mine has none of those, and never did. Slonaker |
#22 | |
.. and they couldn't put the check engine light in a more conspicous spot??? LOL (smack-dab in the middle of my cluster... talk about a bad afterthought)
#23 | |
2) Also, we have to clarify-----just because a truck has an ESC distributor does not mean it definitely has CCC; Yes esc requires a computer, but the esc system alone is a totally different computer system from CCC. However, a CCC truck/car might also have ESC to confuse the issue further.............. Last edited by C-10 simplex; 09-19-2010 at 03:05 PM. |
#24 |
P.S. Right now, i think the blue plug thing is the mixture control solenoid IF the truck has CCC. If the truck is an 85 or 86 model AND DOES NOT have CCC, then it's a dual capacity accelerator pump. But apparently, a truck could be an 85 or 86 model AND have CCC AND dual capacity accelerator pump AND a mixture control solenoid AT THE SAME TIME. Confusing? It's the GM way.
i got the info on pg. 64 of Rochester carburetors by Doug Roe. i think he's a former gm engineer or something. Last edited by C-10 simplex; 09-19-2010 at 03:15 PM. |
#25 | |
