09-14-2010, 05:48 PM | #1 |
Pics of Gray/Charcoal/Gunmetal trucks??
Hello
Im considering painting my truck dark silver, charcoal , gray, gunmetal. Whatever you may call it!! I'd like to see some pics please. thanks J
1969 C10 stepside 1973 Cheyenne Blazer |
09-14-2010, 07:59 PM | #2 |
Re: Pics of Gray/Charcoal/Gunmetal trucks??
Do a search for Ohio dans truck. Or if he sees this hs might put a picture up here.
09-14-2010, 08:47 PM | #3 |
This is a members truck I saved a picture of. Very nice:
09-14-2010, 09:48 PM | #4 |
thats an awesome color! That garage is stacked !
09-14-2010, 10:18 PM | #5 |
Cruzin
just overlook the gray pimer spot
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
09-15-2010, 01:03 AM | #6 |
69 Fleetside
Here's mine - about $400 in Rustoleum rattle cans for everything, cause I had a huge learning curve putting down a metallic out of a rattle can good! - Black Night Metallic, sick color in the sun, flakes are a silver/gold, we shall see how it holds up to the weather around here now!
Need a bit more drop in the front now that the wheels are on After some clear and wet sanding...not bad It goes pretty good...
1969 Chevy C10 Custom Camper - "Frame On" Restoration Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front Last edited by Beatcoaster; 09-15-2010 at 01:07 AM. |
09-15-2010, 07:29 AM | #7 |
Wow...Beatcoaster that is pretty cool for straight out of the can!!!!!!!!
09-15-2010, 10:29 AM | #8 |
Six in a row makes it go...
I know it's a '64-'66 but this one made an impression on me...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
09-15-2010, 11:03 AM | #9 |
09-15-2010, 11:10 AM | #10 |
WOW! Dude -- You did this with Rustoleum out of a Spray Can?!!!!!
09-15-2010, 01:29 PM | #11 |
69 Fleetside
Yap, metallic Rustoleum out of a can over the whole truck, of course it took over a month of nights and weekends! About 3 coats of paint and 3 of clear to get it done. It took a lot of trial/error to get it to lay correctly and look good too, that was the biggest hurdle, getting metallic to lay correctly from a can - ha!. I eventually got it down and after a lot of work was ready to wet sand and polish it. I have a couple areas that aren't as shiny as I'd like(need to resand w/1500/2000 and buff), and a couple places where the clear started to fracture from there being too much moisture in the air when I laid it, but it looks better than the Maaco purple color it was when I got it!! What's nice is that any chips or spots that need touchup down the road are easily done - we will see how the clear holds up the UV over the next year or two, but it has been 8 months so far and zero fading issues.
1969 Chevy C10 Custom Camper - "Frame On" Restoration Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front |
09-15-2010, 01:46 PM | #12 |
Here is mine
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
09-15-2010, 02:03 PM | #13 |
The Older Generation
There are a couple of darker ones in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=380749 LockDoc
09-17-2010, 10:02 PM | #14 |
the boat guy
I really like the new silverado light metallic brown. Saw it on a 54 last weekend. It's just a little more brown tan pewter. If my truck wasn't black I would have a hard time painting my truck any other color.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-03-2014, 02:33 PM | #15 |
Ttt for some new ideas
01-03-2014, 05:24 PM | #16 |
Not my truck but a paint job I like
01-03-2014, 05:50 PM | #17 |
I have been wanting gun metal grey myself for a long time, best that I like so far was the color they used on the Craftsman truck, there was a build on it you can check it out on the 67-72 build threads. That's the color I recently told my body man I want my truck painted. John
