Old 09-14-2010, 10:02 PM   #1
munice
regular everyday normal guy
munice's Avatar
Stuck Axle Bolts 14B FF /Locker Questions?
Hey All , well I finally finished my 3/4t 10 bolt rebuild now im starting the 14bolt, right off the bat, four of the axle shaft bolts wont let up.. One side came apart just fine, not a whole lot of force needed but the other side is being a bugger. I soaked them all in penetrant but to no avail. And I wasn't sure how I would go about heating them up if that would even work.
Other question I had: I'm in Southern Ontario right beside Port Huron michigan, where abouts would i be able to get a Detroit Locker? From my research, Ive gathered that for the 10.5" ring gears the locker just replaces the inside of the carrier. I looked on jegs, but they only had the one for 4.56 and up (mine is 4.11) I wasnt sure if its something that can be ordered through oreilly's or not? Or what other units work for the 14ff's? My truck isn't a serious offroader but it does get to play once in while
here's the finished 10 bolt and the 14
munice is offline   Reply With Quote
Old 09-16-2010, 12:16 AM   #2
DBLSPRT68
DBLSPRT68's Avatar
Re: Stuck Axle Bolts 14B FF /Locker Questions?
Hey, I haven't dug into my 14 bolt FF yet except an oil change. There is alot of info on the net about them. Here is the one I've used. http://www.pirate4x4.com/tech/billavista/14b_bible/ I would think you could heat those up, hit them with a chizel, vise grips......anything to get them off. Soak them with Kroil oil if you can find any. It's the best. Sorry I couldn't help more. Good luck! Front axel looks fantastic!!!!!!!!!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 09-16-2010, 12:25 PM   #3
puppy
puppy's Avatar
The detroit locker fits either series carrier, just make sure you have the "open" carrier. It has 3 cross pins as opposed to the "limited slip" or "gov-lock" which has 4 cross pins or windows as they are sometimes referred to when viewed from the rear with the inspection cover off.
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline   Reply With Quote
Old 09-17-2010, 06:37 PM   #4
dropd80s
dropd80s's Avatar
You got that backwards. The open carrier has four pins, the gov-loc/limited slip has 3.
dropd80s is offline   Reply With Quote
Old 09-18-2010, 01:46 PM   #5
wyattglock
wyattglock's Avatar
Another site that might help with your rebuild is www.diy4x.com, he is a straight shooter that has helped me with some question when I rebuilt the Dana 70HD in my truck.
wyattglock is offline   Reply With Quote
Old 09-20-2010, 09:46 AM   #6
puppy
puppy's Avatar
oops
That is what I get for typing faster than I can think. You are correct, the detroit has 4 pins.
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
