09-15-2010, 01:51 AM | #1 |
belt routing w/o A/C 96LT4 swap
Any way of routing a smaller belt w/o A/C on a 96 LT4 swap? I want to run everything else on the engine, alt. P/S, tenioner and idler. I could run the a/c pump just for a pulley but don't want something that is not working. I don't need a/c. must be a way to do this with out buying differant brackets.
09-15-2010, 11:02 AM | #2 |
Never Ending Projects
Re: belt routing w/o A/C 96LT4 swap
Is this the GM serpentine belt setup? If so, they sell a A/C delete pulley. It basically replaces the A/C compressor with a standard pulley that is the same size. You still use the same belt and routing.
I bought mine from Rock Auto online. About $40 or so, depending on application.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-15-2010, 01:06 PM | #3 | |
09-15-2010, 01:09 PM | #4 |
Gearhead
Thats what I did on my LT1, I had to trim the framerail to allow clearence for the delete pulley though. The pulley sits right in the curved "lip" thats bent up on the frame, I purchased the pulley on E-Bay for a good price, you might check there as well.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 09-15-2010 at 01:09 PM. |
09-15-2010, 03:42 PM | #5 | |
09-15-2010, 04:45 PM | #6 |
Gearhead
Yes mine was a bracket and pulley, you can get all the info and pics in my build thread.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
09-17-2010, 02:21 AM | #7 |
Thanks for your imput I will get a delete pulley, I seen on an other post the you did your wire harness your self I am starting on mine so if you any advice or where to look on line that would helpful thanks let me know. Dave
