Old 09-15-2010, 10:19 PM   #26
Charles Hettich
Re: "The 72" build
mine are 8.5 inch wide. i got the 275's out back. what caps to you suggest? the guy i bought em from sent torque thrust type caps but they dont fit over the front hubs
Charles Hettich is offline   Reply With Quote
Old 09-15-2010, 10:40 PM   #27
Charles Hettich
Re: "The 72" build
those who dont live on miles of gravel, be thankful on the days it rains
Old 09-16-2010, 09:49 PM   #28
Charles Hettich
Re: "The 72" build
i put a coat of paint on my steering wheel tonite! it looks great! as far as i can tell, its gonn match my interior really good
Old 09-16-2010, 09:52 PM   #29
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: "The 72" build
newstalgiawheel.com
They had some caps for slots at this booth in Nashville, this is off the card, they had em at the vendor booth at goodguys, i assume its on there site.
did ya prep your wheel EXTRA good lol, 40 years of greasy oily hands..what'd ya use to fill the cracks (or was there) jb weld maybe or did ya buy the 'special steering wheel repair epoxy)?
PICTURES
John
1999 Toyota Tacoma 4x4
Old 09-16-2010, 09:53 PM   #30
oldblue1968chevy
Re: "The 72" build
DANG you went muddin!
Miles of gravel roads huh..I remember SD as BIG open fields...lots of combines, and more BIG rolling hills!
John
Old 09-16-2010, 10:01 PM   #31
Charles Hettich
Re: "The 72" build
hahah call me wierd but i didnt do anything with the minor cracks on the wheel. i kind of like em. theyre pretty small. you cant even see the metal rod in the the center in any of em. yeah the roads have been a mess!!! you should see it today.... its worse. my poor slot mags. yeah next monday, the progress will slow down due to harvest starting. that will probly run a month. every nite after school till who knows how late
Old 09-16-2010, 10:13 PM   #32
oldblue1968chevy
Re: "The 72" build
haha shoulda jb welded em up!
if ya have to redo it, id jb weld sand/file em down and clean it GOOD lol, imma find a wheel to redo sometime
John
Old 09-16-2010, 10:18 PM   #33
Charles Hettich
Re: "The 72" build
yeah we'll see... if im not happy with it, ill redo it
Old 09-16-2010, 10:29 PM   #34
Charles Hettich
Re: "The 72" build
ive had another modification on my mind for awile. would you think its tacky to put a cb radio in my pickup? im obsesed with semis. almost more than old chevys. ive always wanted one but my dad will never put one in our trucks
Old 09-23-2010, 03:03 PM   #35
Charles Hettich
Re: "The 72" build
ive been plannin out my 383 stroker and ive got a few questions. im gonna go with a 1996-2000 383 stroker block from summit. they said it accepts mechanical fuel pumps. do cams made for factory roller blocks have the fuel pump eccentric on the cam? and it seems like the roller grinds are way hotter than flat tappet grinds and they have the same power ranges. can rollers be alot hotter and still live on the street?
Old 09-23-2010, 08:26 PM   #36
oldblue1968chevy
Re: "The 72" build
yeah throw a cb under the dash and a whip out the stake pocket!!
John
Old 09-23-2010, 10:02 PM   #37
Charles Hettich
Re: "The 72" build
im glad you like the cb idea! ill prolly do it no matter what tho
Old 09-23-2010, 10:33 PM   #38
oldblue1968chevy
Re: "The 72" build
just dont make anything permanent and dont cut any holes lol (in case u change your mind) now send me your wheels/tires lol
John
Old 09-23-2010, 10:43 PM   #39
Charles Hettich
Re: "The 72" build
i thought you had a set of slots off a jeep or somethin. didnt you used to post on the slot mags forum?
Old 09-24-2010, 05:51 PM   #40
oldblue1968chevy
Re: "The 72" build
Yeah I got some slots froma 78 parts truck (frame) I bought
now I just need a 5 lug rearend or some conversion axles $$$$$$$$$$ lol
John
Old 09-24-2010, 11:28 PM   #41
Charles Hettich
Re: "The 72" build
throw a 9 inch in it
Old 09-25-2010, 11:26 AM   #42
oldblue1968chevy
Re: "The 72" build
haha im still working on gettting it tuned right UGH
John
Old 09-25-2010, 06:24 PM   #43
Charles Hettich
Re: "The 72" build
well i orderd summits 383 stroker block. its a vortec block machined and clearanced for a 383 stroker. im still deciding what rotating assembly and cam and heads to go with. any suggestions?
Old 09-26-2010, 12:07 AM   #44
oldblue1968chevy
Re: "The 72" build
i think scat is better than eagle..
heard good things about xe268 for power
John
Old 09-26-2010, 02:36 PM   #45
Charles Hettich
Re: "The 72" build
yeah ive heard scat is better than eagle also. ill check out that cam. i dont wanna go to hot since this is my daily driver
Old 09-26-2010, 02:48 PM   #46
oldblue1968chevy
Re: "The 72" build
Im not sure if that cam is for roller setup or not, I would suggest putting a post in the engines forum
tell your specs rearend gear rpm range etc etc etc and ask for some suggestions
im assuming you wanna build same motor as me but 383 Mines not anywhere closed to being tuned so I cant give you any info on the thumper, ive heard its more of a noisemaker than power maker, it does sound awesome though..
John
Old 09-26-2010, 04:14 PM   #47
Charles Hettich
Re: "The 72" build
yeah ive heard that about the thumpr. but ive also heard they make good power from some people. yeah the closest roller grind is the 270 which is what i think im gonna go with
Old 09-29-2010, 10:02 PM   #48
Charles Hettich
Re: "The 72" build
i ordered the rotating assembly today. i went with a scat kit. its got forged flattop pistons, 6 inch i beam rods, and a cast crank. i think im gonna go with the edelbrock top end kit. they say they made it for the 383 stroker and they claim it makes 460 hp
Old 09-29-2010, 10:11 PM   #49
oldblue1968chevy
Re: "The 72" build
jeez! 460hp!! How much you plan on having in this build if you dont mind sharing?
John
Old 09-29-2010, 10:38 PM   #50
Charles Hettich
Re: "The 72" build
i just did a rough estimation of 4700. but thatd be with everything completed including headers hopefully. but this is my one opportunity and i wanna do it right. ive dreamed of this for like 5 years now
