Old 09-16-2010, 11:10 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
GPS Speedometer Install
The GPS speedometer arrived today so I figured I might as well play around with it. I had a trashed instrument cluster that I could experiment with so I started the modifications on it. The first picture shows the components of the kit. The second shows the lens mod. I cut the hole with a pair of dividers by going in a circle until it cut through the plastic. You might be able to use a hole saw but it would have to be turning very slow and probably need to be cooled with water. Third the tin mod I did with a hole saw in a drill press. You have to go very slow with this too and wear gloves. If it catches it will probably ruin the tin. I let one end of the tin rest against the drill press post as a stop. The fourth picture shows the speedo installed in the tach hole. I didn't have to modify the bezel for the 3 3/8" speedo. As seen in pictures 5 & 6 I soldered the black and white wires from the power inverter to the main power harness wires and used heat shrink tubing on them. This just saves running two more wires out the back of the instrument panel. Picture 7 shows the plug in connector I installed in the constant power wire so all three wires from the speedo can be unplugged. That way the retainer can be unscrewed and removed to get the speedo out of the cluster. Picture 8 shows the connections to the fuse block on my '67 and picture 9 shows the antenna connection on the back of the speedo. The cable is 15 feet long and the block on the end has a really strong magnet in it. Don't get it too close to your Digital camera or your cell phone 'cause it will probably erase the stuff on them…
I bought the white face one because I'm going to order the white decal kit. The last picture is with the speedo set in the stock hole. If a person was going to do this I think the 4" one would look better although it does match the size of the fuel gauge. If it had a black face it would look better too.
Hopefully I will be able to get it put in the truck in the next couple of days but I'm going to a swap meet tomorrow so it probably wont happen then. I will be adding to this when I get it in…
LockDoc
Leon
Old 09-16-2010, 11:11 PM   #2
LockDoc
LockDoc's Avatar
Re: GPS Speedometer Install
More Pics
Leon
Old 09-16-2010, 11:13 PM   #3
LEEVON
Moderator
LEEVON's Avatar
Oh man that's cool! How does it work, do you have to program or subscribe or anything?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-16-2010, 11:19 PM   #4
LockDoc
LockDoc's Avatar
No subscription. Just use it. Works like a GPS. It has odometer, trip meter, clock, elevation, speed, compass, top speed, 0-60 time, and 1/4 mile ET.
LockDoc
Leon
Old 09-16-2010, 11:32 PM   #5
72Levi
Active Member
72Levi's Avatar
That is cool, I love technology.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum
2004 FORD FX4 SuperCrew
2005 CTS-V 12 sec family car
2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it!
72Levi is offline   Reply With Quote
Old 09-16-2010, 11:58 PM   #6
70cst
70cst's Avatar
Now that rocks!!!!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-17-2010, 12:33 AM   #7
Sammy
Way to go LocKDoc.
Only draw back now is if Obama wants to know where LockDoc is, and how fast he's driving that BB, and what direction thru the corn Fields in Iowa, he can find out if it's safe to steal a sample of that outstanding homemade brewed wine.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-17-2010, 06:33 AM   #8
rsavage
rsavage's Avatar
LockDoc,
It looks great. Nice neat install. I know it's early in the am, but it looked like you were installing it in the tach hole and the last pic shows it in the speedo spot. What am I missing? If you don't mind me asking, what does something like that run?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-17-2010, 06:36 AM   #9
rsavage
rsavage's Avatar
Never mind. I went back and re-read the last section of your post. Duh!
1961 C1 Corvette
2021 Durango RT 5.7
Old 09-17-2010, 08:31 AM   #10
LockDoc
LockDoc's Avatar
I'm guilty of doing the same thing once in a while...
Here is the web site:
http://www.speedhut.com/gauge_produc...ometer_GPS.htm
This one was on sale for $220 with free shipping when I bought it. The CableX speedometer converter is $349. It converts from electronic transmission output to mechanical speedometer. For 130 bucks less l thought I would try the GPS.
LockDoc
Leon
Old 09-18-2010, 09:23 PM   #11
LockDoc
LockDoc's Avatar
Installed the temporary instrument cluster with the GPS speedo in it this evening. No problems hooking everything up and it seems to work great... The light is nice and bright and it is easy to read. I will take the Garmin along in the morning to check the accuracy. I put 7 miles on it tonight.
LockDoc
Leon
Old 09-18-2010, 09:36 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work Leon!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-18-2010, 10:08 PM   #13
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: GPS Speedometer Install
Nice look to it. I wonder how it will work in a city envoriment though? I may have to do a whole cluster for my 71. I'm tired of the speedo being off and bouncing all over the place at slow speeds.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-18-2010, 10:52 PM   #14
Hubscrub
Cruzin
Hubscrub's Avatar
that is sweet
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-19-2010, 09:50 AM   #15
Street Lethal '72
Street Lethal '72's Avatar
Hopefully when the time comes I can afford one of these, nice job/write up. I also found a bunch of these as apps for mobile phones, I thought they were neat anyway: http://www.ranosoft.net/palm/speedometer-gps/
But, I think once all is said and done, I will be getting the correct change over speedo gear for the trans (rear gear/tire size adjusted). As this is the most affordable/functioning option for me.
The added functionality of those gps speedos is pretty handy, wish I could get one.. like I said.. hopefully.
Again, nice work!
Street Lethal '72 is offline   Reply With Quote
Old 09-19-2010, 12:11 PM   #16
LockDoc
LockDoc's Avatar
Nice work Leon!
Thanks Nate.
Not sure Andy. I don't have any tall buildings or cities close enough to go try it...
that is sweet
Thanks Hubscrub.
Again, nice work!
Thanks Street Lethal '72. Here is a web site that should help you with the speedo gears...
http://www.transmissioncenter.net/sp...n_______va.htm
Part way down there is a speedometer calculator.
LockDoc
Leon
Old 09-19-2010, 12:17 PM   #17
Average Joe
Average Joe's Avatar
Cool! This would be great for my Nova which alternates from 2.75 freeway fliers to 4.11's.
Average Joe is offline   Reply With Quote
Old 09-19-2010, 02:51 PM   #18
big_al_71
big_al_71's Avatar
looks pretty good thanks for posting the DIY directions. May look into this in the future..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-19-2010, 03:57 PM   #19
Andy4639
Old member
Andy4639's Avatar
I plan on buying one for the 71 soon, very soon! Thanks for the info!
Old 09-19-2010, 08:54 PM   #20
LockDoc
LockDoc's Avatar
Well I put the Garmin in the truck and went for a little drive. The GPS speedo was spot on. I know they get the signal from the same satellite but I wondered about the conversion from digital to the analog output. Also no problem with the crappy, rainy, drizzly, foggy, overcast conditions we had today.
LockDoc
Leon
Old 09-19-2010, 09:11 PM   #21
Hubscrub
Cruzin
Hubscrub's Avatar
good to hear
Proverbs 3:5,6
Old 09-19-2010, 09:51 PM   #22
1968CHEVYC10
1968CHEVYC10's Avatar
And the good part is, burnouts don't add to your mileage
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 09-19-2010, 09:53 PM   #23
ERASER5
ERASER5's Avatar
I noticed that some of the Speedhut GPS units had high beam and turn signals built in. That would be real handy for a clean custom dash.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-21-2010, 01:48 PM   #24
Andy4639
Old member
Andy4639's Avatar
Just called Speedhut and found out they have a 4 1/2" speedo to!
Also when you order there other gauges they come with everything you need to make them work. Cool!
I have to get my Christmas list done now!
Just what the Doc ordered!!!
Old 09-21-2010, 03:29 PM   #25
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice upgrade Leon!
Ryan
1969 Chevy milk truck
