Old 09-18-2010, 04:52 AM   #1
raycow
Speedo cable connection
I need to find out what year the upper end of the speedo cable changed from screw-on to clip-on, and I believe it was sometime during the run of the squarebody style. Can anyone help me with this?
Thank you.
Ray
raycow is offline   Reply With Quote
Old 09-18-2010, 10:59 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Speedo cable connection
Thank you.
Ray
I have a 74 cluster in my hand that is clip on and every other newer one I have seen is clip on style.
What year is the truck you are working on?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-18-2010, 03:18 PM   #3
raycow
Thank you 68 TT. The truck I am working on is a 63, which uses the screw-on type. I am doing a transmission swap which needs a longer cable, and I am trying to find out how late I can go and still get the screw-on end.
It is starting to look like the cable might have changed when the 73 body was introduced.
Ray
Old 09-19-2010, 12:32 AM   #4
westofb
I really hate wet sanding!
westofb's Avatar
Ray
I have a 71, it is screw on connector at the speedo, I would guess they made the change from screw on to clip on with the body change of 73.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 09-19-2010, 01:09 AM   #5
raycow
Thanks Jeff. That pretty well narrows it down so I know where to look now.
Ray
Old 09-20-2010, 11:56 AM   #6
68 TT
68 TT's Avatar
You beat me to it. That is what I was going to say.
