Old 09-19-2010, 10:33 AM   #1
sandorjoben
sandorjoben's Avatar
Where does this light socket/bulb go?
I have a 1987 GMC V15 4x4, gauge cluster has speedo, fuel, volts, oil pressure and engine temp. I just got the truck not all that long ago, and noticed that when I engage the 4wd there is a small light that comes on that's hanging down amongst the mess of wires behind the lower dash near the fuse block and e-brake pedal, it's not attached to anything and just kinda floating around amongst the wires behind there. The socket is similar to the type that plugs into the gauge cluster to illuminate the speedometer, fuel, oil pressure, etc. only it has (+) and (-) wire and uses a GE168 type bulb. Does anyone know where this is actually supposed to go? Like I said it only comes on when the 4x4 is engaged. If need be I'll try to post a pic later. Thanks in advance.
Dave
sandorjoben is offline   Reply With Quote
Old 09-19-2010, 12:19 PM   #2
thinair
thinair
thinair's Avatar
Re: Where does this light socket/bulb go?
is it the bulb that lights up the "4x4" indicator that is located below (can't remember) the speedo or the gas guage??
thinair is offline   Reply With Quote
Old 09-19-2010, 01:50 PM   #3
sandorjoben
No idea where it's supposed to go, i've got kind of a frankentruck goin' on right now, I'll take a photo of the gauge cluster and the light socket/bulb that goes on and post 'em shortly, maybe that'll help sort this out.
Dave
Old 09-19-2010, 02:01 PM   #4
sandorjoben
It was the 4X4 light socket that illuminates the orange 4x4 active light inside the speedo, clip on the socket was broken so it wouldn't stay in the gauge opening apparently. Thanks for pointing that out.
Feel free to delete this thread at admin's leisure.
Dave
