Old 09-19-2010, 06:02 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Headlight pin out
Hello, Im looking for what the pin out is for a stock headlight switch. I have the wire colors traced down and I need to know which pin is which.
Thanks for your help.
Steve
61_FL_Apache is offline   Reply With Quote
Old 09-20-2010, 06:21 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Headlight pin out
1963 Chevrolet
GMC
Old 09-20-2010, 07:05 AM   #3
61_FL_Apache
Who Me?
Thanks, but I have these diagrams. Im looking for a diagram of the headlight switch and which color wire to each pin. there are 8 pins on the switch. These diagrams dont show you enough detail.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
Old 09-20-2010, 07:28 AM   #4
aerotruk63
aerotruk63's Avatar
On my 63.
If you hold the switch in your left hand with the curved metal section pointing down. Starting from the top.......
RED below that'
PURPLE on the right, Black and Brown on the left. Below them.....
EMPTY on the right, double ORANGE on the left. Below them.......
LIGHT BLUE on the right,EMPTY on the left. Below them.............
WHITE on the right, GREEN on the left.
Old 09-20-2010, 08:38 AM   #5
61_FL_Apache
Who Me?
Excellent!! Just what I was looking for.
Thanks again!!
Steve
2001 Blazer 4D 2WD
Old 02-11-2012, 12:07 PM   #6
61_FL_Apache
Who Me?
On my 63.
RED below that'
I am digging up an old post of mine because Im still fighting this issue. With the pin out about this is what im working with. Its not working out as planned.
When I use a test light on the switch, I have power coming in at the top post. When I pull the switch to the first position, the only pin that is hot is the Purple. When I pull the switch to the second position, the purple is not hot but the Light blue is.
When I use both positions of the switch, these are the only two connections that are hot. What I have had to do is wire everything to one post so all my lights come on.
The question here is, why are none of the other post getting hot? This is a new switch I have been working with.
Thanks in advance for your help.
Steve
2001 Blazer 4D 2WD
Old 02-11-2012, 04:23 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I'm not sure if this will help, but it shows a close up of the switch and wiring, and the jumper needed to keep the parking lights on with the headlights:
http://www.6066gmcguy.org/parklamp6466.htm
Old 02-11-2012, 05:23 PM   #8
61_FL_Apache
Who Me?
That is helpful. Thank you!!
Steve
2001 Blazer 4D 2WD
