regular everyday normal guy
Stuck Axle Bolts 14B FF /Locker Questions?
Hey All , well I finally finished my 3/4t 10 bolt rebuild now im starting the 14bolt, right off the bat, four of the axle shaft bolts wont let up.. One side came apart just fine, not a whole lot of force needed but the other side is being a bugger. I soaked them all in penetrant but to no avail. And I wasn't sure how I would go about heating them up if that would even work.
Other question I had: I'm in Southern Ontario right beside Port Huron michigan, where abouts would i be able to get a Detroit Locker? From my research, Ive gathered that for the 10.5" ring gears the locker just replaces the inside of the carrier. I looked on jegs, but they only had the one for 4.56 and up (mine is 4.11) I wasnt sure if its something that can be ordered through oreilly's or not? Or what other units work for the 14ff's? My truck isn't a serious offroader but it does get to play once in while ![]() here's the finished 10 bolt and the 14 ![]() |
Re: Stuck Axle Bolts 14B FF /Locker Questions?
Hey, I haven't dug into my 14 bolt FF yet except an oil change. There is alot of info on the net about them. Here is the one I've used. http://www.pirate4x4.com/tech/billavista/14b_bible/ I would think you could heat those up, hit them with a chizel, vise grips......anything to get them off. Soak them with Kroil oil if you can find any. It's the best. Sorry I couldn't help more. Good luck!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() Last edited by DBLSPRT68; 09-16-2010 at 12:17 AM. Reason: forgot something |
The detroit locker fits either series carrier, just make sure you have the "open" carrier. It has 3 cross pins as opposed to the "limited slip" or "gov-lock" which has 4 cross pins or windows as they are sometimes referred to when viewed from the rear with the inspection cover off.
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
#4 | |
Another site that might help with your rebuild is www.diy4x.com, he is a straight shooter that has helped me with some question when I rebuilt the Dana 70HD in my truck.
oops
![]() That is what I get for typing faster than I can think. You are correct, the detroit has 4 pins.
