Tranny mount for the S10 chassis swap
Has anyone used the hanger bearing cross member as a tranny cross member?? It's kind of light but it is a full square tube. just wondering if it's heavy enough. Your thoughts please.
av8tr33337 AKA Bartman Email av8tr33337@yahoo.comBartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
Re: Tranny mount for the S10 chassis swap
your not gona want to cut that out it keeps the rails from twisting. i used a trans mount from an 88 chevy/gmc fullsize 2wd in mine. go thruogh my build and you will find it.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
![]() Join Date: Jul 2010
I plan to just modify and use the stock S10 mount for my 700R4.
Ben |
I also modified my stock one for my 4L60. I cut it to fit the angle of the frame on the right side, on the left I cut the frame rail and hammered it down to match the original frame mounting spot then drilled two more holes. Here's a picture if you loook closely you can tell how much I had to move it backwards. I too thought about using the bearing cross member, yours is made different than mine. Mine was flatter .
Hey 1952 you need to share your album with us! I want to see all of your build pics to help me with mine
![]() Ben |
Thanks for all the input. I will leave the bearing support alone and go with one of the choices you guys outlined. Thanks
I was a member there first then found this forum and liked this one better because it's more active. I'll check you out over there though!
Ben |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
