Badass
Pulling motor/trans
What's the easiest way to pull them out? I've got a cherry picker. Pull them out at the same time or pull the motor then drop the trany?
305/th350 Posted via Mobile Device
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
![]() Join Date: Dec 2008
Re: Pulling motor/trans
at the same time
^ really?
You have to get the engine AND tranny high enough to clear the core support. Most cherry pickers won't lift one that high, plus you're talking about something over 1000lbs. Pull the 6 tranny bolts and unbolt the torque converter, use a floor jack or blocks to support the tranny, then lift the engine squarely out. Jack the truck up under the front crossmember and you'll get enough ground clearance to slide the tranny out. |
It depends on what level of tear down you want to do. It is not hard to pull the radiator and core support to pull the engine and trans right out of the front.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 09-20-2010 at 06:05 PM. |
^^x2^^ thats the way i would do it plus gives you more room to Cleaned up the engine bay some
Salty Sailor
x3
86 c-10 Custom Deluxe Savannah, Georgia |
Yeah, and it gives you the chance to wash your floor or driveway with tranny fluid
![]() The times I really think twice about this is with the 90's engines. The sonsab!tches at GM decided we needed pinch nuts on the studs that bolt the engine and tranny together, and while we're at it, we'll do it to all 6, those are some of the worst cramped positions and S L O W, regardless of how you wrench it. I just find it a lot easier when those are stock type bolts to unbolt everything, it lets me keep my tranny fluid where it belongs and I get to lift the engine straight up and out. I understand there are tools that allow you to grab the flexplate and turn it a good bit at at time, but I do my penance for the job by using my big screwdriver. |
Happy to be here
![]() Join Date: Mar 2000
Two fer one job there. Pull the clip and clean and paint while your at it.
Considering he is going from a 305 to a 400 I was thinking he may need extra room when he puts everything back in
will you lose that much transmission fluid ? i Always change fluid and filter at this time anyway unless just done recently Last edited by nbpro; 09-21-2010 at 06:44 AM. |
Badass
got everything off the motor (lines,hoses,wires,exc) core support is staying and so is the radiator.
good luck looks like you have your mind made up keep us posted
#15 |
good luck keep us posted
#16 |
i have pulled them clear over the radiator support with motor and trans many...many..many times before....but my truck have always been pretty low.
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
#17 |
BAD BOW-Silverado XST
#18 | |
Badass
but would i need to unbolt the whole trany cross member so the trany can go down?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
