09-21-2010, 03:42 PM | #26 |
Re: GPS Speedometer Install
That is very nice. I though about adding a GPS permanently to my dash, but that looks allot nicer. The really nice thing about that is no matter what tires you are running it will be accurate. My truck with 36s on it is up to 20MPH off at times.
10-13-2010, 02:40 PM | #27 |
The Older Generation
I finally got the instrument cluster done. I had WAY too many interruptions but that's the way it goes.... I have to figure out what to do with the choke hole to hide the background. I may have to try and find a stock choke cable. LockDoc
10-13-2010, 03:35 PM | #28 |
6>8 Plugless........
Very nice Leon! Is that a tach on the lower right inside hole?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-13-2010, 03:49 PM | #29 |
Old member
Did you spread the anntena out in the dash or leave it bundled up?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-13-2010, 08:38 PM | #30 |
Wow I LOVE that dash cluster ,it looks so clean .
10-13-2010, 08:53 PM | #31 |
great idea, never thought of it....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-13-2010, 08:57 PM | #32 |
Eat, Sleep, Drive a Chevy
lol...so true
Looks good
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
10-13-2010, 09:14 PM | #33 | ||
Thanks Guys,
Dieselwrencher: Quote:
Andy4639: Quote:
LockDoc
10-13-2010, 09:29 PM | #34 |
Thanks Leon. I didn't know they sold gauges there.
10-13-2010, 09:36 PM | #35 |
http://www.harborfreight.com/automot...sh-gauges.html They almost always have them on sale for 20 bucks each at the stores. LockDoc
10-13-2010, 09:42 PM | #36 |
Old member
I'm going to take my dash I have now out of the truck and put the 4" speedo in it where the factory speedo is. This will happen sometime after the first of the year. Hopefully I'll get the new shoes for the truck also then.
10-13-2010, 09:55 PM | #37 | |
Sounds good Andy, post up some pictures when you Git'erdone. LockDoc
10-13-2010, 10:03 PM | #38 |
Old member
I plan on it Doc. I may even buy one for the golf carts and build a pod so I can swap it in and out when I need to.
Could you post a shot of the antenna as it's mounted? Wondering how it would work just left under the dash or does it state in the directions it has to see day light?
10-13-2010, 10:10 PM | #39 |
RAT1968 '68 Cab/'71 Parts
Me, too! Wish I could do the $peedo. Not right now, tho.
Nice work!
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
10-14-2010, 04:16 PM | #40 |
nice work
Doug Looking for a 67-72 short bed driver..... |
10-14-2010, 05:07 PM | #41 |
Big Red - Now its a SWB!
Cool idea!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-14-2010, 10:48 PM | #42 | |
Sorry for the delay Andy. I just got in from the shop. Actually they recommend putting it on the roof..... I figure if the Garmin works good on the dash this should too, and it does. It could probably be moved over to the left side without any problems. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-14-2010 at 10:49 PM. |
10-15-2010, 09:06 AM | #43 |
Old member
Thanks that was what I was thinking, maybe run it to the back window? Can or does it state that it can be verticle and pickup signal? I was wondering if there is enough cable to reach the back window. This is fine just thinking.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-15-2010 at 09:07 AM. |
10-15-2010, 09:29 AM | #44 |
whow! Leon ,,you have out done yourself on this one..very good job and tested out to be accurate too.. If your name was Tom ,,I would have to start calling you Tom Terriffic.. (an old hero of mine) LOL
10-15-2010, 10:12 AM | #45 |
Champagne Taste on Beer Budget
LockDoc,
Very cool write up and nicely detailed instructions at that. Was thinking seriously about adding this to my setup in the future. Can you please give a website or phone number where to find this? Thank you kind sire.
Coming Soon: Project 1970 Country Truck |
10-15-2010, 10:39 AM | #46 | |
LockDoc
10-15-2010, 10:41 AM | #47 | |
LockDoc
10-15-2010, 10:45 AM | #48 | |
Thanks for the kudos. See link in post #10... LockDoc
10-15-2010, 12:29 PM | #49 |
Opps! My bad!
I sometimes skim over things a bit fast. Another question for you on your setup. Not seen your truck but some of us drive thru the woods and wondering if trees or city driving with large building around would cause any issues? Would love to have this for my project truck just a bit skeptical about this new technology product. Any thoughts?
10-15-2010, 03:13 PM | #50 | |
I can't give you an honest answer on those questions right now. I don't want to go off road with this truck and there are no tall buildings within 60 miles of me... LockDoc
