Old 09-21-2010, 08:44 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Question Coolant hose to throttle body.
I know alot of people say it's needed but I am trying to see if anyone has just plugged it with no issues. I have an air lift to fill the coolant system with so air bubbles arent an issue. It will not get cold enough here for the t.b. to need it either. So, is it really needed or not? Any help would be great. Thanks guys.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-21-2010, 10:18 PM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Coolant hose to throttle body.
I ran mine from the steam line cross over pipe back into the water pump. I have run several back to the upper radiator hose and the top tank with out any overheating issues. The line runs from the throttle body to at least mid tank on the stock radiator so air probably isn't much of a concern. Lots of the Ls guy bypass the TB so it shouldn't be much of a problem. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 09-22-2010, 10:14 AM   #3
Clyde65
Clyde65's Avatar
My 2005 motor came with all blocked, no line to the TB.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-22-2010, 01:57 PM   #4
STOCKISH
STOCKISH's Avatar
Cool, I'll plug it and see what happens!
--Josh
Old 09-22-2010, 02:11 PM   #5
LEEVON
Moderator
LEEVON's Avatar
If you do that, at least leave the ports open while you add coolant and purge air from the system. I've heard (not experienced) that steam/vapor can get trapped and affect cooling if it's not vented. I'm like you though, can't hurt to try without long as you're watching temps. Let us know how it goes.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-22-2010, 02:25 PM   #6
jephs422
I've bypassed every one I've done with no issues.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 09-22-2010, 10:49 PM   #7
STOCKISH
STOCKISH's Avatar
I have an air lift which is cool. You hook it to the radiator and pull a vacuum on the system. Then the vacuum pulls the coolant into the radiator and fills the entire system without a bit of air. Saves me alot of time when doing repairs at the shop.
--Josh
Old 09-23-2010, 09:54 AM   #8
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Are you talking about bypassing the hose through the TB, or doing away with the steam line altogether?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-23-2010, 02:28 PM   #9
STOCKISH
STOCKISH's Avatar
I dont care about the steam pipe from head to head just trying to clean up the install a bit by not running the hose from the throttle body to the radiator.
--Josh
Old 09-23-2010, 02:40 PM   #10
glock35ipsc
Gotcha. It doesn't have to pass through the TB. In fact, your can just grind that whole bit off of the TB to clean up the looks, as it's not ported through the TB at all. It's more of a heat sink just hanging off of it.
But personally, I wouldn't do away with the line from the heads to the radiator/heater hose/expansion tank, where ever one prefers to run it. I would think that even with pulling a vacuum to fill the system, there is still a risk of getting a bubble in one side the system (one head or another) from the hot/cold cycle of pushing fluid into the overflow reservoir when hot, then possibly pulling air back in when cool if the tank runs low. The manifold on an old small block would let an air bubble circulate out the top, but without that line in place the Gen III's can't do that.
At the very least I would run a short line to the water pump.
Bob
Old 09-23-2010, 03:02 PM   #11
STOCKISH
STOCKISH's Avatar
Mine doesnt run from the head to the radiator at all. It runs from head to head and to the t.b. and then to the radiator. Thats why I was wondering if I could just plug the t.b.???
--Josh
Old 09-23-2010, 03:19 PM   #12
glock35ipsc
If you are just wanting to bypass the TB, yeah, go for it! Like I said, it is not ported through the TB, it's just like a heat sink hanging off of it, so cut that puppy off and grind it smooth. It really cleans up the looks of the TB a bunch.
Bob
